I was on the HWY yesterday driving home from work, cruising at approximately 130 Km/h when suddenly the CHECK ENGINE LIGHT comes on, Saying CHECK ENGINE, VISIT YOUR DEALER, and about 10 seconds later DRIVE START CONTROL MULFUNCTION - VISIT YOUR DEALER. I noticed that the engine temperature started to climb up to above 80% heat, so I pulled over to the shoulder, shut the car off and called a tow truck which towed the vehicle to the dealership. It was dropped off at closing time, so just this morning they checked it out and told me the water pump is dead, and that it needs a new battery and a clean and reset of the Throttle position sensor as the vehicle automatically entered limp mode upon the codes manifesting. This is a full time Uber/Lyft vehicle with 153,984 Km/s on the dash. A month ago the dealership replaced the fuel pump on the vehicle which was covered under recall. This is now the first mechanical issue the vehicle has had, only did oil changes and basic tire/brake service. I am in Canada Ontario. Photos of the dash have been attached, and bellow is a quote from the dealership on the work needed:
INSPECTION REPORT:
2 CODES PRESENT IN ECU-P210900 THROTTLE POSITION SENSOR MIN PERFORMANCE
P26CA31 ENGINE COOLANT PUMP NO SIGNAL
P26CA31-PERFORMED ACTIVE TEST ON WATER PUMP. ELECTRIC WATER PUMP WILL NOT CYLCE. TESTED POWER AND GROUND FROM IGNITION SOURCE AND RELAYS. ALL POWER AND GROUND ARE CORRECT.
REPLACE WATER PUMP AND RE-CHECK 3.0 (CHECK FOR ANY HEAD DAMAGE DUE TO VEHICLE OVER HEATING, NO HEAT IN VEHICLE AT THE MOMENT.
REPLACE BATTERY 0.3
P210900-THROTTLE PLATE COULD BE STICKING DUE TO LACK OF SERVICE. RECOMMEND THROTTLE BODY SERVICE AND RE-CHECK THROTTLE POSITION
PERFORM FUEL INDUCTION SERVICE 1.6
PRICE PARTS
ELECTRIC WATER PUMP
2 JUGS OF COOLANT
BATTERY
INSPECTION REPORT:
REPLACE BATTERY 0.3
PRICE PARTS
ELECTRIC WATER PUMP
2 JUGS OF COOLANT
BATTERY
TOYOTA REPAIR ESTIMATE | W | |||||||
ext 3735 | ||||||||
DATE: | 2021-04-22 | $134.88/HR | ||||||
QTY | DESCRIPTION | PART# | PARTS $ | P-TOTAL | LAB HRS | LABOUR $ | TOTAL | |
1 | ELECTRICAL DIAGNOSES | $0.00 | 1.0 | $134.88 | $134.88 | |||
1 | REPLACE ELECTRIC WATER PUMP | 16032-F2010 | $523.03 | $523.03 | 3.0 | $404.64 | $927.67 | |
2 | COOLANT | C0009-00120 | $20.44 | $40.88 | $0.00 | $40.88 | ||
1 | USED COOLANT RECYCLING FEE | $2.24 | $0.00 | $2.24 | ||||
1 | BATTERY REPLACEMENT | C0PBS-8435F | $156.00 | $156.00 | .3 | $39.95 | $195.95 | |
1 | BATTERY TERMINAL PROTECTOR | $11.95 | $11.95 | $0.00 | $11.95 | |||
1 | FUEL AND AIR INDUCTION CLEANING | $67.95 | $172.00 | $239.95 | ||||
$0.00 | $0.00 | $0.00 | ||||||
VIN: | $0.00 | |||||||
SUBTOTAL | $802.05 | $751.47 | $1,553.52 | |||||
CUSTOMER # | TAX | $201.96 | ||||||
TOTAL | $1,755.48 | |||||||
APPROVAL:___ |
