Hey guys, this is actually for a 3S-FE-equipped 2000 RAV4. Thought I'd post here because (a) our RAV4 forums are dead, and (b) it's almost exactly the same as our 5S-FE's, except 2.0L and has an A247E transmission instead of an A140E.
Several months ago, I replaced several failed components: ECT sensor, EVAP solenoid, valve cover gasket. It was also throwing codes for the upstream AFR sensor's range/performance, and a lean code. The owner had replaced the upstream sensor with a brand-new Denso to no effect. There were no vacuum leaks; it turned out to be a very chewed-up positive battery terminal and original battery. Replaced those, and it passed smog, they went on their merry way.
Now it's developed a problem: after it warms up, it will intermittently stumble in gear, at idle. Idle drops from 650 or so down to 400, then jumps back up as the ECU corrects it. Throws no codes, and does not do this in Park or Neutral. Sometimes it'll do it once, then be fine for a minute or two, sometimes it'll do it multiple times then be fine for a while.
I did some research and it seems this is a very common problem, and nobody has come up with a surefire solution. Couple people solved theirs through stuff like replacing the TPS or cleaning the IAC. The IAC is clean and functioning well (also swapped with known good part, same thing), and so is the throttle body.
At idle, the TPS reports 10.2 steady. I graphed it and saw it dip initially (down to 8 or so) when it stumbled. I then made sure the TPS connector was pushed onto it all the way and it didn't dip again during a stumble.
The truck has 267k on it, engine and trans are original. Cylinders all are 200+ compression, and I have no records as to when ignition components were serviced. I'll check spark plugs tomorrow.
What do you guys think? I'm hoping you can help me pinpoint this problem which seems to have eluded everybody for the past 18 years.
Thanks as usual.
Thanks as usual.
