200-250hp with a naturally aspirated 4a is going to be difficult. There were the Formula Atlantic 4a-ge engines (worth a google session), but they went to pretty extreme measures to get to that power. 10k is not going to cut it for something like that.
Wouldn't be very streetable to drive either. 😏
A 7A-FE cylinderblock (1800cc engine found in Celica's, Carina's, Avensis etc) with a MRP strokerkit to get it to 1900cc might be a good starting point. A 4A-GE cylinderhead would probably be the better choice over your current 4A-F head. Either the 20 valve heads or 16 valve heads would be a good starting point.
Fuel injection will get you further with a broader powerband and is easier to control. You'll need a elektric pump and good sized injectors for that. Your carb engine now only has a mechnical fuelpump.
Then go for high compression, uprated valvetrain, uprated (ARP) hardware, cams, ITB's, a nice exhaust header with freeflowing exhaust front to back and a standalone ECU with high redline. You might be able to get near the 200hp with a decent powerband and decent streetability. Would be a nice project. But no guarantees for any of that to get you to those numbers, as nobody really does this because of the costs.
You might also want to start thinking about dry sumping the engine at this point to ensure oil will get through the system and reducing drag and crank pressure etc.
But by this point, we're talking about pulling your current engine, frankensteining a completely different engine from several engineparts and a shitload of money to get to that 200hp. It's basically going to be a racingengine.
I would be looking into a different gearbox (probably E series instead of your current C series) and axles too while you're at it, if you want it all to stay in one piece for a while...
But this is just thinking out loud with money no object...😂
