5S-FE vs. F22A
18K views 119 replies 33 participants last post by  TTercel
damn you honda! :headbang:
5S-FE
2162 cc (2.2L) Inline 4-cylinder
DOHC
87mm Bore
91mm Stroke
135hp @ 5400 rpm
145 ft-lbs tq @ 4400 rpm
9.5:1 Compression Ratio
F22A4
2156 cc (2.2L) Inline 4-cylinder
SOHC
85mm Bore
95mm Stroke
130hp @ 5200 rpm
142 ft-lbs tq @ 4000 rpm
8.8:1 Compression Ratio
both have economy heads that dont flow great, but that can be fixed with machining ... both have similar blocks and make EXTREMELY similar numbers ... also have similar applications
but of course, the F22 is a Honda engine - which means an aftermarket ... so thats why people have F22 cars running 9sec 1/4 miles and we have 5S cars running 18sec 1/4 miles
:thumbsdow :sosad: :ugh3: ... was just talkin it over with some local car guys, its sad really
i've always wondered why there is so much aftermarket support for honda than toyota. the sad thing is that its like this for pretty much all of toyota and honda lineups. i cannot understand why there are more aftermarket parts for an accord than a camry. it really seems like if you drive a honda, you have your own endless choice of mods while we toyota guys are stuck with trd - if the parts we need exist - or some super expensive brand because nobody else makes it but them. its really sad.
#48 ·
Its even more sad for the owner of the V6 accord. However this would never happen with the 98-99 V6s. They are a bit quicker than 00-02. Also when swapped with 6speed tranny, the car is a totally different animal. It should have come from the factory like that! I just seems like Honda is a bit more lazy with their V6 drivetrains compared to their I4s:disappoin
BTW lets not even get started on the 95-97 V6 Accords:ugh3:
#9 · (Edited)
since we are on the topic of limited mods for a camry, i have some questions about the choice of mods for a camry. i've been driving an 97 i-4 camry sedan for about 2 weeks now and i have to say its a pretty solid car. my previous car was an 1987 corolla sedan (ae83) that has been in my family eversince my uncle bought it new. that version of the corolla never had the aftermarket support of the corolla gts (ae86), i thought since i would be driving a fairly new car, the choice of mods would be there. i was wrong since most of the good mods are available for the v6 model.
so far, all the mods i've done are cosmetic like changing my headlights to h4 hid bulbs and changing the green oem dash lights to red ones. i decided i will not go all out in terms of mods since it does get costly and it really is a disease. the next mod i will be doing is changing the exhaust pipes and exhaust. i'm gonna go with 2" piping and i really want to go with a chamber exhaust cause going with a cannister type would look ridiculous since the camry is a family car. i will most likely get a magnaflow xl cause i like how it sounds and how it performs - i had one for my old corolla. however, i haven't decided whether to go with an 2.5" or 3" outlet. i know opening the exhaust will reduce low torque, but allow better flow for higher rpms. i would like suggestions based on experience, nothing theoretical.
after exhaust, i'm thinking about intake and air filter. i know k & n is a highly reputable company, but does anyone have experiences for intakes from other brands?
i will most likely leave springs and wheels/tires as the last things to change. i seen springs from tein that drop the ride quite a bit, but are pretty expensive. wheels/tires will set me back $1,000+ so i'll leave that for later if i do change it.
#94 ·
I have an Injen Short Ram Air Intake for my 99 I-4 Camry LE for about 4 months now and it runs really well. And for an exhaust, I would get the 2.5-3" outlet/inlet IMO. I'm going to get a universal magnaflow muffler for christmas, I would install myself, but I'm not allowed too, hehe. GL with mods man...
i dislike honda's for various reasions but if you put a 1mz into a civic you would have a hell of a beast... :/...
so as to not cause an uprise of "your lame" 's and "get off the forum" 's i hesitantly mention
GSR or K20 swap into a 3rd gen that had the 5s :) (you complain about aftermarket support i bring up ideas that should be forsaken, and really are :/...)
though the ultimate would be building a new subframe for the cam cutting a drive line and going 2jz or 1jz :/... *daydreams of drifting around in a RWD camry*
wheres the AWD info at? didnt someone take the all-track and attempt at putting it in a sedan 3rd gen?...
if anyone knows i really wanna talk to them or have an update to see whats up with it, i know one specific person was going to do it or pondering it :p btw you know who you are and i say to change it up when you do install a rav4 hoodscoop :p it will look sick *top mount* *nuff said*
#11 ·
it is a real shame. honda and toyota are so similar in their aproach to cars but honda discovered that little VTEC thing and until the VVTL-I, toyota hasnt had anything like it so why would anyone bother when VTEC is what makes honda cars stand out and good for modding...even the ones without VTEC:lol:.
#14 ·
How many people are running F22A4 SOHC Hondas at 9 sec 1/4 mi? I bet most have the DOHC H22, or DOHC b series engines.
#18 ·
its not about how many, its the fact that there is at least one - i watched the video ... i know the difference between an F-series, B-series and H-series noobcake, and my friend and i were discussing the F22 ;)
b-series is even worse, so dont get me started on that ... its comparable to something like a 3S-FE at best :lol:
how many 5S-FE's have hit 250hp? probably enough to count on two hands ... not the same with F22s :disappoin
#16 ·
o was goofing off last night after work and a friend of mine was driving next to me revving so i was like "ok ill make you feel ashamed" and after pulling 2-3 car lengths and them not gaining any ground i let off the gas as to avoid a ticket... :/ after words we went and bs'ed the car was down shifted into 3rd from a 40 mph start and all i did was put it in second and turn off O/D :/...
AKA Honda cant touch the 1MZ :) *dont quote me on that i realize there are acceptations*
#23 ·
#26 ·
Well everyone knows honda is the aftermarket parts slut. Yet anyone can build one becuase they're so forgivable, But to build a toyota( other than the supra). Its all custom all the time. plus its a more respectable build becuase of difficulty of parts.
#27 ·
OK, that's a Honda Insight race car that ran 9.6 seconds....now I'm not saying it was easy.....but it ain't an Accord though. Honda Insight from the factory weighed less that 1,900 lbs! Now ditch the hybrid system, batteries, airbags, ABS etc, even adding the weight of a roll cage and other safety eqpt, I bet that car is still under 2k lbs.
Oh well, I guess I don't understand this thread.
#28 ·
i never said the word accord, did i? i promise that if you remove your doors, trunk, hood, carpet, and trunk junk you will still not be running 9 second 1/4-miles in your Camry
my point is that there are two identical engines - and one can be built to for high hp with ease, while the other is constantly labeled as weak with no potential
yes, the aftermarkets are vastly different and thats why i hate honda ... but even still, there have been people that have built the 5S-FE custom, which doesnt require an aftermarket, and they still cant get the 5S to do what the F22A does
#41 · (Edited)
Well smarty pants, I am going to turn this thing full circle, buckle up.
How could the Accord NOT be mentioned? You drive a Camry, it has a 5sfe....the "competing" F22 sits in the engine bay of....you guessed it, an Accord. If I removed the hood, doors, and trunk; that wouldn't save over 1,000 lbs plus the aerodynamics would suck. So yeah, you're right at no chance at 9 sec 1/4 mi.
I wouldn't say the Honda engine in this case is built with "ease". Can you buy a header for the F22? Yes, but you also buy one for the 5sfe. Can you buy an intake for the F22? Yes, but you can get one for the 5sfe too. Can you buy a bolt on turbo kit for an F22 Honda? Yes. There is one for the 5sfe too (Burien Toyota)...or at least used to be.
As far as the Toyota 5sfe being "weak" that is usually more of a word we TN'ers use for the power, but not necessarily the engines durability. We say "weak" because in comparison to the fairly potent V6 engines that were optional, it is weak. It's also weak compared to the potent 3sgte..........and oh yes. That brings me to my next point; the fact Toyota makes a 3sgte probably makes it just as easy to turbo your Camry as it would be for a Honda guy to turbo his accord. Many parts are interchangeable requiring some modification, but easier than starting full custom.
But ultimately a lot of people swap in the "better" motor anyway instead of all the work required to make a 5sfe awesome, just drop in the 3sgte altogether.
Hating Honda is stupid, there I said it. Honda owners should hate Toyota because they made turbocharged engines from the factory for years and years. :rolleyes: One thing I DO agree with you on is Honda's popularity, I don't know why, with modifiers. Here's the thing, there are SO many hooked up Hondas, that they are almost a dime-a-dozen. Amongst the Honda crowd, there is actually big bragging rights to have a the quickest/fastest/best SOHC engine, because it was/is so easy and common to utilize the H and B series (and now K) engines. This is how a lot of the potential performance came about for the F22 engines. But I stress, it's not as easy as you make it seem.....especially 9 seconds.
