94 Camey V6LE. 415,000 km. The rad is orginal never change before. Last week (7 days ago) when I turn the a/c on.The temp. gauge is a little bit higher than normal (3/4 up to high). So I shut off the car. Let it cool down a little and continue driving the car back home. Last Thursday I drove the car again without turn the a/c on and is back to normal. So I assume everything is good.
So 2 days ago. I change the oil and flush the Rad. till is all clear and fill it with water and also fill up the over flow tank. And let it run for 20 mins and next day. I see the overflow was empty. That good I guess. I drain the water out to make room for new antifreeze.
Top the antifreeze up then let the car run and keep topping it up. There is a lot of bubbles come out and I keep on fill it up till it full. But still there are a lot of bubble come out from the rad. I think there should be enough antifreeze in the rad. almost 4L. I top up the overflow too.
Go shopping. The car running normal no sign of problem but when I also get home. A lot of smoke coming out from the hood. I pull over and look's like the Rad. got blow up. The over fill tank still full. 6 hrs later return to the car and add 4L of water in and still not enough and keep on adding water total around 5L (No more water) and I hear the water start leaking out somewhere but was too dark can't see where. I guess must be the top part of the rad. was crack. So I drove the car home because is not very far like 5 KM and the weather is cool can't leave it at shopping mall overnight. I think I need to replace the rad. that's o.k.
My question is I google "How to replace the 94 Rad" and come across soemthing call
"Rad with Bubble" and people said it might be a Brown Blow gaskets
and cause the bubble. And I just change the oil too and the dirty oil look's normal no
sign of antifreeze inside the oil and the oil cap is clean like normal not what they claim yellow. in color..Humm
The Camry have no problem before and I remember there are a lot bubbles comes out too last year when I flush the rad. When I let the car running with the cap off while topping up. The air bubble like shotting out from the Rad. I don't know is that normal or not.
I guess/Hope it might because I flush the rad. and clean up all the dirt inside and cause the rad. to leak. I flush the rad every year anyway. This is the first time I have problem. Anyway is about time to change the rad. Hope is not what they claim Brown Blow Gaskets. I don't what to see after I replace the Rad. and got blow up because of that or will it.
Thanks !:facepalm:
Sub0
Thanks !:facepalm:
Sub0
