95 Camry - Intermittent No Power/No start- Nothing
5.9K views 9 replies 4 participants last post by  71Corolla
Got this weird problem just started happening-
Put key in ignition and nothing- like a dead battery. No lights- silence.
Open hood, everything is connected fine. (Battery is new BTW)
Get back in car, turn key, turn key.... and eventually when it feels like it- it suddenly comes back to life, starts as if there was never a problem. A little disturbing since I don't want to be stuck somewhere and not have it start. At gas station today I had asked a guy for a jump,but got it started before he pulled up. When I told him the story he said it sounds like the computer- based on his own Camry experience.
Sound familiar anyone? This has happened 3 times in the last 2 weeks.
No power, lights, nothing. It's exactly like a dead battery.
The open door light isn't even on, however, I know I'm back in business because the open door light is suddenly again shining bright as ever- but only because whatever the problem is goes away by itself.
A defective battery? Not sure I've ever heard of that happening, at least not one that goes 100% dead one minute and works the next. Your issue sounds like a bad ground actually, or a bad positive terminal connection. When the car goes dead, open the the hood, leave the drivers door open, and tap or move the connections near the battery you should be able to track down where the intermittent problem is. (you'll hear the door chime when you get a connection).
Turning on the headlights will also be a good way to tell when the connection comes back.
#9 ·
This happens from internal hairline fractures. Usually from one or both of the terminal posts. This can happen with cheap batteries with poor manufacturer standards or using used batteries out of wrecked vehicles.
Complete power loss can happen completely randomly or whenever heat is applied.
