My cousins 95 Camry would not start the other day. Someone sprayed starting fluid around the intake and it started and then died. It warmed up later that day and worked find. two days later same thing. It won't start and it is cold.
Yes, I have read this forum. I was cranking the car and no fuel was pumping out of the line.The pump only runs when the ecu receive crank signal that the engine is turning.
See if this help:
95 Camry LE V6 no power to fuel pump
95 Camry LE V6, 1MZ-FE V6 engine. No power to fuel pump. EFI relay and open circuit relay all work fine and have power to the terminals (including B+ terminal), all fuses fine. Hard to believe it's the hard wire problems. Any insights and suggestions highly appreciated.www.toyotanation.com
