Noticed for about a week now, the engine sounds like it is working noticeably harder right after the starter turns over, and it stays that way until I put the car in gear. It also sounds like it is working harder when I accelerate in 1st and 2nd gear. Once I get the engine warm and over 30mph or so it is not so noticeable anymore. I've read everything on this, from exhaust leak to timing belt (the timing belt was replaced about 30K ago).
When it starts the engine seems to idle at about 1500-1700, then drop to about 1000 when I put it in gear. I'm not sure but isn't 1500 a bit high for idle?
Anyone had direct experience with this?
98 Camry V6 with 193K
Thank you!
Thank you!
