I don't have a part number for the spring. Looking on an online Toyota dealer catalog, it may be 90507-17003 (searching on 99 Camry LE 2.2 5SFE). However, the accurate way to tell is to give a dealer your VIN number. It's about $3.50 plus shipping, so locally it's going be a bit more but cheap enough to get a new one. Besides, the picture on the web catalog is wrong. LOL
BTW, the Amazon seals you listed are Fel-Pro! You need to lube the rotating seals on install. OE ones from the dealer come with dabs of greases from the factory. Sometimes they smear all over the plastic bag however. LOL
Fel-Pro has always worked for me and are my first, go-to seals. No problems. In fact I had more problems with Victor Reinz, but others experienced just the opposite. So I guess it's a toss up which one you pick. Of course, you can look on McGeorge Toyota (or other online dealers) and get OE oil seals.
parts.mcgeorgetoyota.com
Also, this discussion on the different springs may help, and based on the discussion, the silver one with the stronger tension should be the correct one. This makes sense as Toyota was having problems with timing belt knocking loose under the cover.
I have read that there are two types of timing belt tension springs for the 4 cylinder 5f-se engine out there. An original one and an updated one. They have a different number of coils and I assume a different length. The FSM only mentions a green or silver color difference each with a Free...
www.toyotanation.com
BTW, in the DIY section you might have seen already:
Part 1: Timing Belt and Oil Seals Replacement 5S-FE (w/ Pictures) Car: 1996 Camry, 4 cyl., 5SFE, Auto Trans., 191000 miles Project: Timing Belt and Oil Seals Replacement Hey Everyone I recently changed my timing belt and the oil seals: camshaft, crankshaft, and the two oil pump housing...
Part 2: Timing Belt and Oil Seals Replacement 5S-FE (w/ Pictures) **************************************************** Continued from Part 1 --> http://www.toyotanation.com/forum/4003328-post1.html **************************************************** ====== PART 2 ======= I washed everything...
I decided to do a timing belt job on my '00 camry. It has 91,000km on it and the schedule maintenance factory sticker says replace every 100,000km. I felt bored so I decided to do it early. Here are the parts I bought in advance: Timing Belt S$45 Timing Bearing #1 S$25 Timing Bearing #2 S$30...
DIY: 1996 Camry Timing Belt + Waterpump + Oil Seal Change 5S-FE (GEN3) - Part 1 Part 1.... I completed this procedure at 203,000 km on my 1996 Camry 2.2L Auto (5S-FE Engine) . The timing belt, drive belts, water pump, idler and tensioner had previously been changed at 103,000 km. The cost of...
DIY: 1996 Camry Timing Belt + Waterpump + Oil Seal Change 5S-FE (GEN3) - Part 2 Part 2......Click on the link below to go to Part 1 of this procedure....... http://www.toyotanation.com/forum/showthread.php?t=264425 ¸ 40. Clamp the oil pump pulley in a vice. Remove the nut, then the pulley...
The DIY section:
For Gen 3 & 4 Camry owners who want to do-it-yourself with regular maintenance, repairs, and modifications, listed below are links that may provide the help you need. It would also be a good idea for any person doing DIY work to purchase a Haynes or Chilton manual that will answer most any...
