Hi, I have a 99 Camry with the 2.2L. that has a no crank no start and am looking for some guidance. I went out to start it one afternoon after driving it top the store and it didn't crank or start. All other power is fine (lights, radio etc..) I checked all the fuses and relay's and found the 5amp fuse in the dash was blown so I replaced it. When I tried to restart the car that fuse blew again.
I have checked the battery - it's at 12.6v. Checked the constant power from the battery to the starter, it's at 12.6v at the starter. I also pulled the starter and had it checked at my local AutoZone, no problems with it. I have replaced the ignition switch, starter relay and the neutral safety switch. I also had to replace the main negative battery ground wire since it was a little frayed. None of these have helped and am still having the same issue. The starter engages for about 1/2 a second when I try starting it, then the 5amp fuse blows.
I can get the car to start by replacing the 5amp fuse in the dash, pulling the starter relay, turning the ignition key to on then jumping the starter relay points 3 and 5.
I'm now trying to find out why that 5amp keeps blowing. Any help would be appreciated!!
Thanks!!
Thanks!!
