I have a 1984 Celica GT. Two weeks ago, the A/C stopped working. I've tried a lot of things and I'm at my wits end. Any help is appreciated.
Symptoms:
Not sure if it's worth mentioning or not, but when the engine is running, the A/C button is pressed (RPMs are up), if I put one multimeter probe on the wire running into the compressor and the other probe onto a ground, I'm not getting any voltage.
Also, when I took the pressure switch from the evaporator, I tried a continuity test on it. Putting one probe on each prong, no continuity was found. Not sure if that's normal or not. Then I got a new switch. It did not have continuity either.
What else can I try? What else could it be?
Symptoms:
- Originally the A/C cabin switch did not work. Found the 10A fuse in the passenger footwell was bad. Replaced the fuse and the A/C switch started working.
- Blower works. Warm air comes out of the vents.
- Compressor does not come on.
- When the A/C switch is pressed, the RPMs come up as expected.
- Radiator fan comes on immediately when car starts.
- Checked heater relay and circuit breaker. Both passed, but if I'm reading the wiring schematic correctly, the cabin A/C button will not function if circuit breaker, relay, or fuse is broken. So I believe the A/C button working verifies that all 3 of these are functional. Correct me if I'm wrong.
- Evacuated system.
- Replaced compressor and drier.
- Vacuumed system. System held vacuum for over an hour.
- Tried to recharge, compressor would never come on.
- Replaced pressure switch inside the evaporator box.
