a240L
384 views 9 replies 2 participants last post by  tony's 1989 ae92 sr5 4a-f
The na aw11 came with the a240E automatic transmission. Does the flex plate fit the A240L corolla transmission?
Do you have the p/n of the torque converter you want to use?
Almost to the point of seeing both in person. Not sure the torque converter bolt pattern will mean much if it's between a 6 or 8 bolt flext plat. In the past the 8 bolt has neen a problem finding for any job that needed a new one.
I don't have a part number but it is from an 89 corolla sr5. After some ebay browsing apparently the same torque converter is used for mr2 and loads of other toyotas like my corolla or even a newer pontiac vibe/matrix but I'm not sure how accurate that is but i think its enough to say that it will work just because of toyota being toyota and reusing the same parts on everything
