Well, got the Wheeler's 1.5" AAL installed and the 5100's (front set to 1.75). The ride is soooo much better than stock. No more bouncing on the bumps on the freeway and side roads. Can't believe how much they absorb the road. All around a huge improvement!
Now for the downside. I have to read through the 35 page vibe thread. I can hear/feel it easily around 35 - 45 mph and it can't be heard/felt once past 50 mph (sounds like I'm driving with MT tires instead of AT tires). I guess it really is hit or miss just like 08TRDOFFROAD said. I really needed that AAL to help out with the firewood hauling. I guess I would have had the same problem with the rear-leaf spring TSB if I'd had it done and wanted to level the truck.
I'll have to read more on that thread, but I noticed that a lot of people thought it had to do with the driveshaft. But that just doesn't make sense. It instantly goes away when switching into 4HI (like a light switch, turn it on, turn it off). BUT, it still does it if you switch into neutral and coast which takes the load off of everything (unless you're in 4wd then it doesn't do it even in neutral). That leads me to believe it definitely has to do with the front differential or transfer case.
I can't remember if it was Fortech or someone else that explained what's happening when you switch to 4WD, but I did find it interesting that the vibe goes away when switching it to 4WD EVEN IF it never locks up! I was driving on a straight-away stretch on dry pavement and couldn't get it to lock up, but the vibe went away anyway. So what's the order in which the 4WD system engages? Transfer case goes immediately based on the switch then we wait for the solenoid in the front differential...or the other way around?
