ABS Delete
10K views 16 replies 8 participants last post by  GaryQ
I have a 2007 Highlander Hybrid. The ABS module has gone bad and I don't want to replace it. The module continues to buzz and be a nuisance. I tried removing a number of the fuses from the box under the hood but lost braking completely. Does any member know how to delete the ABS and have the car revert to traditional braking?
#7 · (Edited)
It's not a competition. I've got 202K on the car. I really don't expect any of the parts to last that long but, the abs has shit the bed and the part new is $1700.00 and the best used on eBay is $500.00, so I don't see why they should have any problem w/ me pulling the plug. I just want to know which plug. ABS is an advantage but marginally at best. People drove for 100 years w/o it.
I've always thought safety recalls can't expire. Just because the owner at the time either ignored it or didn't know about it doesn't mean the car should be left on the road unrepaired, And with a brake related issue it's not just the driver and occupants of that car, but every other car on the road. Open recalls are easy to check. Just go to safercar.gov and put the VIN in.
#11 ·
Whoa I literally came to this forum to ask about this exact same thing for my 2006 HiHy. The non stop buzzing has only happened to me once so far, but then after leaving the car off for an hour, it decided it was fine again and stopped. @Horatius could you perhaps link me to the $500 part on eBay that you saw? Is there a fixed one with a different part number or are they just the same?
#13 ·
As a general rule, please, be VERY careful choosing parts for hybrids online. They tend to be wrongly advertised as fitting hybrids. I'd say, best, though more price, bet is to find one of them online Toyota dealers that has decent pricing.
That's how I ended with a perfectly useless to me and no one wants to buy it now axle for my 2012 HiHy. So I learned my lesson. Online dealer. Safe.
Btw, that "recall" was not really a recall. It was "warranty extension". They might be jumping some legal loopholes with that, just like with oil consumption in Camry Hy engines. But I am pretty sure it had "expiration date/mileage" on it.
#14 ·
Unplug the beeper. It's mounted up above the brake pedal. It's just a little Black Box about the size of a relay. If you fabricate and ABS brake delete your gas mileage will suffer. With brake codes the regenerative braking won't work. With an ABS brake delete kit regenerative braking won't work. The brakes are very much tied to a hybrid system. My brake actuator is currently bad. Why is it there's cheap options for Prius owners but Not Highlander owners. I'm thinking of stealing parts from my spare Priuses for trying to retrofit the Highlander brake actuator and make it work again.
why is it that no one's taking these things apart yet and found out what the common failure is. I'm sure we don't need to rebuild the entire thing, just the part that's commonly failing everyone.
#16 ·
Can't you guys get the needed parts from the salvage yard? There's probably a ton of em written off.
and defeating/bypassing ABS could make you criminally responsible if it was discovered, and the law would be the least of your worries in the states, lawyers from all 3 sides (theirs, your insurance and your own blood sucker lawyer) would have your last drop of blood.
Reactions: Bear&Meg
#17 ·
When an ABS part fails it triggers the ABS warning indicator. That disables (technically) the ABS function. when that happens you are obligated to get it fixed. Removing or disabling the light is not considered a fix.
Reactions: Bear&Meg
