I would like to Know what terminals i need to connect to get the codes to troubleshoot my ABS light and E brake light that is on. And what the codes mean Please. 2007 Yaris
I did this a while back and no problems still. Behind the rear drums unplug the "only" electrical plug you can see, give it a full clean out with whatever product you favour (I used WD40 then air pressure to dry off). You will need a small screwdriver as its a bugger to seperate the connection. Put it back together and hey presto.
Good Luck
