AC Compressor Repair
3K views 11 replies 10 participants last post by  kenshiro
We have a 2022 Highlander Platinum which has been working well.
A few days ago, the AC ceased blowing cold air. Took it to the dealer and was told that we had taken a rock through the grill, which punctured the system. 2K and a new compressor later, I am wondering if anyone else has had this issue. The maintenance guy at the dealership told me that ours is the third one he’s had with this issue.
Anyone else had this issue?
Is there anything aftermarket that can be added to prevent another incident?
I think by 2022 all AC compressors are variable displacement type, so that should be a reasonable assumption. With the refrigerant all leaked out, which also carries lube oil, the compressor can seize from lack of lube. The variable compressor swish plate spins all the time, it only changes its angle to vary the displacement volume.
There are plenty of types of mesh, whether the basic wire mesh I used, or the more stylish looking diamond shaped meshes.
#8 · (Edited)
This is what I put on the inside of my grill to block foreign objects from getting thru. I simply cut it to the shape of my grill and used black zip ties to keep it in place. Does not affect the performance of the radiator at all and barely noticeable. There have been many complaints about damaged condensers from road debris.
Modengzhe 40 x 13 inch Car Grill
