AC recirculation inlet vent
47K views 14 replies 7 participants last post by  Sandman1221
Does anybody know where is the air inlet vent located for AC recirculation?
I love the specs, but do you have any actual photos of where the recirculated air intakes are under the dash and by the brake assembly? My Dealership has said I need to spray lysol or something like that up into the intakes in order to neutralize the rodent smell from the nest they made in my cabin air filter, which they removed.
It is a large opening located behind and above the glove box, just above the cabin air filter. A swinging door covers the inlet when the system is in fresh (outside) air mode. In recirculated air mode, the swinging door unblocks the recirculating inlet and moves to a position where it blocks the duct to the fresh air inlet (located under the cowl).
Recirculated air passes to the inlet through gaps around the under dash panels and brake pedal assembly, as well as through slots in those panels. It is a matter of semantics whether the slots should be considered the actual inlet.
If you think the system is increasing the cabin humidity when in recirculate mode with the compressor off, the problem could be an obstructed evaporator drain. There could be a puddle of water in the bottom of the plenum that requires some hours to drain.
If you drive slowly on a paved driveway with the compressor on (assuming it has been on for awhile and the outside air is humid), there should be a trail of water drops along your path.
#11 ·
Spraying Lysol into the opening will not be adequate (I know because I also once evicted a mouse family from my cabin air filter). It is more effective to spray a rag with the Lysol and wipe down the inside of the duct, above and below the cabin filter slot.
To accomplish this, first remove the blower. It is located just above the passenger foot well and fastened with just 3 screws. You will need a "stubby" (short) driver for the rear fastener, because the angle of the floor restricts access.
Remove the connector and the 3 screws, then pull down the blower assembly and set it aside. Also remove the glove box door and cabin filter. Now you can reach up into the duct through the blower opening and thoroughly clean it, along with any residue that fell into the blower.
On my 2015 Venza 2.7 L was getting a musty smell with just fan running, so I removed the cabin filter and with the AC system running I sprayed Lysol (50% ethanol version) into the intake area exposed by the cabin filter, sprayed for so long that a mist of Lysol started coming out of the vents! That eliminated the musty odor and it has not come back.
