2009 Camry 4cyl
I changed my PCV valve over a month ago and still have white smoke coming form exhaust on startup. The smoke goes aways as always, after that the smell is gone and the car runs like normal. The smell of the smoke is not really sweet as if it was coolant leaking, but its not exactly smelling like burnt oil either (I've had cars that burnt oil real bad and it smelled different than this camry).
I've been keeping an eye out on my oil and coolant levels, both seem to be ok. I refilled my coolant tank to full about 2.5 months ago as it was very low and its still almost at full right now. My oil after about 4k miles on the dipstick measures right in the middle of the min and max dots, which it has been for as long as I've owned the car. So these levels are ok I think.
Now, I've read somewhere a while back that after changing the PCV valve or rather after taking the old one off that there still will be some residue to be burnt off. A way to get rid of that is to create a makeshift vacuum by plugging one end of the hose (the one that attaches to PCV valve) and leaving the PCV valve off while running the engine, putting some kind of cloth or similar over where the PCV valve should go to collect all the burnt stuff, thus cleaning the remainder out. Is it possible that this might be the a solution?
Thanks!
Thanks!
