Hi guys,
I'm reaching out to you to get some help or advice. I bought an aftermarket fog light kit for my 2004 Matrix on aliexpress that came with wiring and everything.
The fog lights were pretty easy to install in the front bumper and I figured out how to pass the wiring through the firewall without too much trouble.
As I was searching through the forum, I found a topic where someone used the dimmer switch to tap in the power and ground wires from the new fog light switch. Problem is, my dimmer switch has different wire colors and I can't seem to find the right ones to tap in.
Currently, my power wire is attached to the red/black wire and ground is on the black wire. The switch light appears, but as I activate it, the relay buzzes and the fogs don't light up.
Here are pictures for reference.
Thanks for the help and sorry for the long text!
Sent from my LG-H873 using Tapatalk
