AGM BATTERIES
11K views 50 replies 9 participants last post by  bennor
Question: does anyone use a AGM battery. I wanted to know how good they work. How people like them and if they are worth the money. Thanks.
#11 ·
Also not long enough to get the engine to full operating temperature and boil off condensation and combustion acids.
Longest trip of 4 miles would be the one and only time I would recommend oil changes at 3 months or 3000 miles, but the solution is to get the car out on the road and run it at highway speed for an hour or so every weekend.
Daily trips of 4 miles are slowly destroying that engine.
#9 ·
Bull- AGM should be better for constant short trips however replacing standard battery every couple of years gets you a free replacement.
AGM will probably last past the warranty but then you'll pay for a replacement.
As to which AGM is best can't say.
Sears carries Diehard.
#20 ·
98 corolla. My wife’s batteries just don’t last with the constant short trips and under charging. We have been using Interstate battery. Brand really does not matter if she is constantly under changing battery with short trips.
You can buy and hook up a battery tender. Once or twice a week you can plug it in to keep the battery happy. It should lengthen the life some.
#17 ·
An AGM battery may work better, but it might not fix your problem.
I don't care about brand so much as to which model you use. Most brands have low grade, middle grade, and high-end battery. It makes a difference. My original Motorcraft battery that came with my truck lasted 6 years. Then the Duralast Gold I replaced it with lasted 7 years. Then I replaced that battery with an Everstart Maxx and it is about to hit 7 years.
If I bought the cheap "value" batteries from Duralast, Everstart, etc. they would not have lasted nearly as long.
#26 ·
It's still going to die.
The only thing the AGM battery will do for you is MAYBE last longer between replacements, because they are more tolerant of being deep-cycled than conventional batteries.
Conventional batteries can lose a significant percentage of their capacity with each deep cycle event. AGM are more forgiving, but will still ultimately fail.
The question is, if the AGM costs 50% more than the standard battery, is it going to last more than 50% longer? I doubt it. I don't think the cost/benefit is there.
If the vehicle is garaged, plugging it into a Battery Tender is the best solution.
Driving on a discharged battery is hard on the alternator and charging system as well. The systems really were not designed to be constantly charging a dead battery, they were designed to provide a maintenance charge.
#23 ·
A battery maintainer would work. You do have to plug it in to a receptacle. Not an issue if you keep the car in a garage or have an outdoor receptacle near by.
It is inconvenient to have to hook it up and unhook it from the battery every time you use the vehicle. And you don't want to accidentally drive off with it still connected.
#27 ·
Battery Tender is a specific brand (and it works very well).
Battery Maintainer is simply a generic term... many companies make them, but Battery Tender is one of the better ones, as it was designed for this purpose.
Most battery chargers have a "trickle" mode, but they can still tend to run a bit higher than is really best for the battery.
#28 ·
Cb. So even if I get a AGM battery that can Handel short trips the alternator can not Handel short trips.
So you think it would be better to stay with a regular battery and 2-3 times a week drive on a long drive and also use a battery.
Cb my wife drives her forester ever day just never on a trip long enough to charge battery. Thanks
#30 ·
and OP is asking about a Subaru, not a Toyota.
So you're saying that the alternator will die an even earlier death than we might expect? 🤣
But seriously... Physics is physics and doesn't change from brand to brand.
Charging a dead battery is very stressful on the charging system, and driving only 4 miles a day will still likely result in the need for frequent jump-starts and more frequent than expected battery replacement.
#33 ·
Bull, is your current battery under warranty? You should be using this when the battery acts up. The standard warranty is between 2-3 years. After that, they prorate them. Need to make sure you’re buying the correct battery for your car. Size and cold cranking amps specified by the manufacturer.
Invest in either a battery tender or battery charger. Or even a Noco jump pack.
Edit : AGM batteries should only be used on a vehicle that has a need for it. Like a big stereo system. The cost of a AGM is much greater than a lead acid battery.
#35 ·
This. No need for a battery for a Corolla of this generation that is still simplistic. Group 35 for this one!
Reactions: 75aces and cb91710
