'03 XLS with ~100k
Installed new ceramic pads & rotors about 5k ago.
No leaks, system tight.
Probably LONG overdue for fluid flush & bleed (pedal a bit soft).
Familiar with manual flushing procedure and have done so many times before ABS became common on vehicles. However, I have questions regarding brake flush since this car has ABS. I've seen other forums noting a need for "odd" sequencing of wheel order plus specific methods to flush thru ABS hardware & valves (such as needing ignition key ON, scan-codes generated, etc). I don't have the Shop Manual (unfortunately too expensive for me). However, is there anything "odd" or "specific" I should know before diving into a brake fluid flush on my XLS? Is the sequence order the typical starting with "furtherst from master cylinder first"? I'm not looking for a step-by step (I'm comfortable with that). I'm looking for issues that might be specific or unique to flushing thru the ABS hardware on the XLS. Thanks in advance for any replies.
