at what speed does a 93 corolla shift into the next gear
8.5K views 51 replies 8 participants last post by  new echo owner
at about what speed
will a 93 corolla dx 180L automatic transmission ... in D ... be shifting
into the next higher gear
with an L 2 D overdrive
with overdrive ON
empty ... with only the driver
new tires ... 32 psi
at light throttle ... which means easy acceleration ... on a straight level paved surface road ... with no wind ...
  • i am 69 years old ...
  • this transmission shifts so smoothly
  • this engine runs so quietly
  • i have no rpm gage to see when shifting into the next higher gear takes place
here is what i am looking for:
  • at about ... __ mph ... from 1st ... into 2nd gear ...
  • at about ... __ mph ... from 2nd ... into 3rd gear ...
  • at about ... __ mph ... from 3rd ... into 4th gear
thank you for your help
#2 · (Edited)
not so sure what you are asking here
auto tranny base when to shift on the amount of load on the engine (through a few sensors). in other words, if there's little stress on the engine, it will most likely shift up. if there's heavy load on the engine, it'll stay in low gear a bit longer.
the surface of the road, slope of the road, how hard you press gas, number of passengers in the car, even tire pressure all can affect when it shifts. since yours is a 4 spd, it's controlled electronically by the ECM. it decides when to shift base on the inputs of some sensors in the car.
there's no set point on at exactly what speed or rpm it shifts, just like manual, it's based on the driver and situation.
I part of it has to do with pedal pressure; more throttle and it will shift higher, less it shifts lower. At least that is a guess; mine seems to have no rhyme or reason as to when it shifts out of second, being anywhere between 41-48 MPH. There is a max allotted speed though for each gear, but I don't know if that plays into it in normal driving conditons
are you sure? because during slow acceleration my corolla is in 3rd around 30 mph. step on it a little, it shifts around 35 to 3rd. wouldn't it make 3rd gear completely useless for local driving if the tranny shifts to 3rd at 60mph?
when speaking of trans shift points, we usually only speek of the full throttle shift points. the reason is its alot easier to tell when the pedal is exactly 100% applied than it is to guess position like 50%. what one says is 50% may really be only 40% or may be 70%.
#9 ·
The factory only provide spec for full throttle test; however, this is what I usually go by:
At light throttle, which means easy acceleration:
1 to 2 12 to 18 mph
2 to 3 22 to 28 mph
3 to 4 32 to 37 mph.
Of course, everyone accelerates differently, but as long as you are close to those ranges, things will work out fine. And there is also the torque converter clutch engagement too.
The TV cable needs to be properly adjusted, and it can also be adjusted one way or another if needed.
N.E.O.
#23 ·
Echo, we noticed the problem for several weeks, and now that the temp has gone down it takes a little longer to shift (only 2nd-3rd) We will monitor the shift points and can report when the transmission is warm. I am not sure what everyone is telling us about lockup? Is there no solution to fix this? Is the transmission bad? We have 165k now. Still in great shape. Thanks everyone.
#25 ·
The torque converter clutch is kind of like a manual transmission clutch disc, that mechanically engages the engine and transmission together when the vehicle get up to a certain road speed, approximately around 35 to 45 mph. The TCC, like the OD in a 4 speed automatic, is inhibit by the ECM until the engine reach a certain temperature, about 130 degree F. When the TCC engages, you will notice some rpm changes in the engine, but most of the time you won't even feel or notice this change, unlike a gear change.
Monitoring the operation of your transmission will help identify whether you are having problem with your transmission or not, and determine what the next step would be. It may even be as simple as changing a thermostat if the engine is taking too long to warm up to the temperature for the OD and TCC to operate.
N.E.O.
#26 ·
Bitter, yes we replace the thermostat in September, I think it was 192* thermostat, and it changed the warm-up time. It didnt help with the very slow to shift 2nd-3rd ,that we are getting now. No one thinks a change of filter will make a difference? What I don't like is the 2500 RPM on the way to work 40 mph for the first mile or so. Thanks again
#29 ·
echo, Yes it seems like 2nd-3rd. You atre right on the filter, it woul affect all shifting. What about the shift solenoid valve? Grasping now. Thanks
Its possible but, it will be difficult to verify to know for sure that is the cause. The two shift solenoids work together to achieve all four gears. I would suggest taking note of the shift points both cold and warm, rpm if possible so there can be some comparision on what the transmission is doing.
N.E.O.
#34 ·
Only two shift solenoids:
Sol 1 On, Sol 2 Off, 1st gear
Sol 1 On, Sol 2 On, 2nd gear
Sol 2 Off, Sol 2 On, 3rd gear
Sol 1 Off, Sol 2 Off, 4th gear
It is a matter of how the fluid is directed and what clutch pack is engaged that different gear ratios are acheived.
N.E.O.
There are 3 valves, not two. What you said is true as long as the shifter is in the D position. The other valve is your L/U
2 shift valves and your L/U valve
Also, if they are malfuctioning, he should have a CEL and a code.
#35 · (Edited)
You are correct about having three solenoids but we are only concern with the ones that are changing gears. We are trying to figure out why he has a delay 2-3 shift when cold, not that it is not shifting. Right now, we need to determine if the shifting problem is only during cold operation or if it is all the time. And I don't think he is manually shifting his transmission, so we can assumed that he is driving with it in 'D', otherwise, he wouldn't be asking about it. Maybe he doesn't have a problem, but until we have all the information, I am not going to say either way.
N.E.O.
