ATF or Power Steeering Fluid
48K views 14 replies 8 participants last post by  CISA93
I have a 2008 Avalon with 111,000 miles on it. I was messing around under the hood and noticed the power sterring fluid looked very dark. I bought a turkey baster and a quart of power steering fluid and did maybe 4 exchanges. During this process I finally paid close attention to what it said on the power steering reservoir "Use Dextron II or III ATF fluid." So, I started exchanging the power steering fluid with the ATF. My question is, does it matter? Can you use either?
I disconnected the return hose and attached a longer hose towards the bottom of the engine (removed right front tire), placed the hose in an empty gallon and ran about 4 quarts of synthetic ATF . I used to do the "turkey baster method" it's good and saves some time, but I didn't see where it removed all the fluid. You must use enough fluid through the entire rack/pinon, pump and hoses to clear the old fluid. I performed this service at 60,000 because of the color of the fluid and where I live. If you decide regular ATF, just use sufficient fluid to flush your entire system:thumbsup:
My '04 baseline 4 cyl Tacoma and wifes '06 Avalon both indicate ATF in the owners manual.
I find that interesting as both came from the factory with power steering fluid; not ATF - the later looks like cranberry juice.
There was no mistaking the content in either PS reservoir.
My mother-in-laws '07 Camry 4 cyl - same as my 2 cars - has power steering fluid in it; not ATF.
I've never seen UNDYED DEXRON on any auto parts shelf. It may exist - but not widely.
The plain jane power steering fluid works just fine in all my Toyotas.
Has been in my oldest(2004) for 8 yrs - no issues.
Use what you like.
#9 ·
I've never seen UNDYED DEXRON on any auto parts shelf. It may exist - but not widely.The plain jane power steering fluid works just fine in all my Toyotas.
You have a cultural problem as do many other Americans. "Power steering fluid" is NOT Dexron auto trans fluid. "Power steering fluid" is a fluid meant for American cars.
Toyota instructs owners worldwide to use Dexron ATF, but many Americans refuse to listen:
1) The cap on the Power steering fluid reservoir usually says "Use Dexron ATF"
2) The owners manual and factory repair manual say use "Dexron II or III ATF" in the power steering system. Toyota has specified Dexron throughout it's history - from the very first Toyota with power steering around 1970 (Toyota Crown) to the 2011 Camry.
#13 ·
Only vehicles that I'm aware that use specific type of P/S fluid are Hondas/Acuras. I DID use ATF and PS fluid once...and ONLY one time because the seals began to leak. All the posting about ATF on Toyotas are accurate. Now...for those that FEEL that synthetic is the "incorrect" fluid or "may cause leaks" are incorrect. I've done this on numerous cars (unless specified i.e. Hondas, ect) and never suffered any leaks from R/P units. You DO NOT have to go as far as I do, but as I believe in auto maintenance and "prepare for the worst, hope for the best" and because like ATF fluid, heat is a contributing factor to oil breakdown Nonetheless, flushing, regardless of the fluid you choose is a great preventive practice on every P/S unit
Grandpapa: Sorry I didn't post photographs, but this is what I did. I placed some old rags under the P/S reservoir, removed the radiator overflow tank (just slip it out gently and completely remove it). You can move the suction hose (the bigger hose) and then remove the return hose (about 3/8 transmission-type hose) I removed my P/S tank, dumped the oil, sprayed a little brake cleaner in there, but didn't let it sit because it doens't interact will with the plastic on these reservoirs. I then sprayed some diluted purple cleaner (50/50) and let it sit for about 1/2 hour. I then boiled some water and let the reservoir sit in a bucket. In the meantime, I removed the return hose, install a slightly longer one, ran that into an empty gallon sitting in the engine compartment. I attached a metal funnel with those small metal screens at the bottom and then proceeded to run about 3 quarts of Dexron III/IV until the oil came out clean. I used an air hose to blow out the reservoir there are 2 screens at the bottom of the reservoirs (suction and return). I used slightly less pressure as to not blow out the screens. There was black gunk in there, sludge like material (74000 on the car). Once it was dry, I reintalled the hoses, clamps and refilled the reservoir with about 1/2 quart, then added some more after moving the steering wheel to work out the bubbles. Now...this is a much longer process, but this assures me, that I flush out of the crap out of the system, the reservoir and I run clean fluid through the system. It will take you more time. Total price I spent was under 25.00 for the oil. I replaced the return hose clamps with fuel injection clamps and the hose, replace once by the dealer in late '07, was seeping. I got a Dayco ATF 300 psi hose and installed better clamps. Much more better now. If you were here, I'd help you do this because there dealer does the machine suction and bada bing bada boom and 90.00 or so later, the job isn't done the right way. So I took it a few steps further, but I know that I've done it right! Best of luck! BTW, you may want to remove that front right engine mount about three or four bolts, it's much easier and when reinstalling it, use anti-seize since they are being attached to aluminum.
