Status
Not open for further replies.
AWD in CVT
4K views 50 replies 14 participants last post by  Gasssman
2021 Venza. Is AWD disengaged when using CVT in manual mode? I recently had an accident while driving on ice at low speed 40kmh. I had returned to automatic mode of CVT and immediately the car began slipping and went off the road. I’m wondering if I wasn’t in AWD while in manual mode and the slipping started when the AWD reengaged?
I don’t drive our 2023 all the time as it’s my wife’s car, but I have driven it a bit in snowy conditions and felt that the traction was consistent with AWD working. Not la definitive answer but it would be hard for me to believe that AWD is disabled when using the minor bit of extra control the fake shifting provides. Frankly, it helps slow the car down better is snow/ice.
Save
Manual Mode in Venza? I am not aware of where you can control any gears. All you have is Sports Mode/Normal Mode/Eco Mode which changes the mapping of accelerator pedal. This does not change anything how the CVT operates or if Rear motor is powered or not.
In the MID if you select one of the screen it shows you which wheels are being powered. Typically from start Front and Rear axles are powered, and after 15 MPH it powers down the rear motor in a straight line. But if there is any steering input rear motor will be engaged until around 22-25 MPH. Not sure what it does at high speeds if it is ever engaged. It probably, but never observed during my drives.
There are some reports that the rear electric motor powering the AWD system in the Toyota hybrids such as the Venza and RAV4 actually shuts off above a certain speed (some say somewhere between 35-50mph). Not sure how accurate those claims are. The AWD monitor would indicate if the system was operating at all speeds or not.
#16 ·
I did some digging, that seems to be the case with Gen 4 Prius called AWD-e which can't operate above ~40 mph.
RAV4 Hybrid/Venza is "Electronic On-Demand AWD" which can be operated at all speeds. But in at low speeds during acceleration, in turns and during braking its always engaged, but after that normally disengaged. But if it detects the slippage it will reengage the rear motor.
During last couple of winters I tried to observe that in the MID at highspeed driving with snow on the roads. There was no explicit slip at that speed, but I feel AWD gives more stable feel during those times. But again my observation is very limited.
#13 ·
AWD is great but it's dependent on at least one tire having traction. AWD, traction control, ABS and stability control all working as designed isn't going to be a bit of good on ICE where there is nothing for the tires to bite into. Even the best 4WD systems in the world need at least one tire to have traction; a Toyota Land Cruiser isn't going anywhere on a sheet of ice. AWD/4WD tends to give drivers a false sense of invincibility in winter weather.
#17 ·
Folks, I did some testing in "S" mode, mean manual selection of ratios, AWD engagement is same as in standard "D" drive mode. All 4 wheels are getting power initially, and if there is no slip detected and no steering input, it cuts off below 15 mph. But if there is curve, and how aggressive the drive is, AWD is engaged even at 35 MPH ( in both "S" mode as well as "D" mode).
I Could not create slippery situations at highway speeds to validate the AWD enagement, but based what I read, it engage AWD if slip is detected. (unlike the old Prius system).
#25 ·
That's what people have complained about for years. It works great unless you need it. Then it sucks!
Yes it does, I sure don’t depend on it anymore. If it does work it will only last as long as you have battery to power it.
#26 ·
Don't take it otherwise, but this does not make any sense. Venza always engage Rear Wheels when starting from stand still. You can observe this in the MID (display behind the steering if you select the correct screen).
Only possibility I can think of, rear wheels have good traction but its very steep that rear motor power/torque is not enough to move the vehicle.
#34 ·
So, display shows power going to rear wheels, but rear wheels does not slip, and car does not move forward? May be there is some issue with your Venza, you should have recorded and went to dealer. As you have seen the two videos above, those are quite steep and its able to make it. You could show the dealer your video and those videos and ask them to check it out.
The Venza Rear Motor is 53hp, 89 lb-ft, so that's the max torque you could get from motor, and there is reduction increasing the torque, no additional ratios as its single reduction gear box.
#42 ·
All the numbers add up but why would Toyota advertise 219 HP when it has 390?
Because they measure/advertise the maximum usable HP that can be delivered to the wheels to propel the car.
Save
#49 ·
Please keep on topic, political discussions will cause posts to be deleted or threads to be locked.
Forum Rules | Toyota Nation Forum
4. Forum Administrators/Moderators reserve the right to determine what material is inappropriate and to modify/delete/move inappropriate forum postings without notice. Inappropriate postings include, but are not limited to, political, racist, profane, threatening, or pornographic material.
Status
You have insufficient privileges to reply here.
