Batteries for Corolla
47K views 24 replies 14 participants last post by  KillaLax
Many of those who bought their Corollas in 2008 are probably close to needing a replacement sooner or later. Just wanted to get a feeler for what works best on our cars and what not. I'm planning ahead and wanted to get familiar with them until the day comes where I need to replace.
From my research, the XRS uses the Group 24F battery as found on the bigger Toyotas like the Camrys, while the 1.8's use the more common Group 35 size. Finding a 24F is more challenging, as many parts stores lump all Corollas as 35 BCI. The best seem to be from Costco, Walmart and the Toyota Truestart brand, which are all made by same Johnson Controls. However, Costco does not seem to have a 24F battery in their selection, which sucks since their prices are good and the warranty coverage is awesome. The Walmart (Everstart Maxx brand) is the one I'm eyeing next, if not the Toyota Truestart battery. There is a True 2 battery that is comparable to the Duralast and Plus Start from the Autozone, Sears, etc.
#6 · (Edited)
Batteries are like snake oil. Only a few manufacturers slapping hundreds of "brand name" labels on very few different batteries.
EverStart MAXX sold by Walmart is an excellent battery made by Johnson Controls... Just like batteries sold by a zillion other retailers under different names INCLUDING major vehicle brand names like Mazda, Acura, Mitsubishi... etc. There are plenty of good options out there.
Edit: Check out this page: http://jgdarden.com/batteryfaq/batbrand.htm
#16 ·
Not sure how many different batteries each manufacturer makes, but I worked retail and I remember re-stickering our batteries so the 48-month batteries became 60, the 60's became 72, and the 72's became 84-month, but the actual batteries didn't change, so ...
#9 ·
I have a Everstart MAXX in my 99, not bad, first battery lasted 3 years and got a free replacement 2 months ago. I just installed a Toyota TrueStart to replace the original battery in the 07. It was $90 + $16 core charge.
I just replaced my battery in my Corolla. The dealer Toyota warranty was 2 years full on the battery and 50% coverage in the third year. They wanted $45 to install the battery.
So the best choice was to get my own battery and install it myself. Canadian Tire wanted $120, The Energizer battery at Walmart was $89. Same 3 year warranty, but includes a card the entitles me to 3 boost if I need it. Walmart beats CDN Tire.
#18 ·
Alternator wouldn't affect steering.
If you have a hard time steering the car, it's possible the belt that drives the alternator also drives the power steering pump and that broke - which would be an easier repair.
#20 ·
How is the steering affected?
If the belt is intact and the battery was charged and it dead again, that would indicate (in order of likelihood):
  • Alternator is faulty and not charging the battery - pretty well confirmed by the light on the dash.
  • Wiring fault between alternator and battery (most likely confirmed by replacing the alternator and the battery still not charging).
  • Current draw or other short drawing the battery down (also most likely confirmed by replacing the anternator and the battery still not charging).
BTW - you want to charge the battery again before you replace that alternator as a weak battery puts more strain on the new alternator.
#22 ·
I found out that the alternator is the problem along with the battery.
You might be able to just charge the battery again - but if it's been discharged several times, it might not work.
The batter doesn't have enough power to charge the alternator to get it to work.
Got those reversed. The battery is charged back up by the alternator.
So I'm going to end up replacing the battery and alternator
Safest option.
#23 · (Edited)
This generation of Corolla doesn't have a power steering pump. The power steering is provided electrically, so it seems like low voltage could affect the power steering.
Unfortunately, I have seen where a bad battery has taken out the alternator. Replace the battery and see if the charging light goes off. If not, then it's time for a new/rebuilt alternator.
(EDIT) Just saw the other thread. Posting the same problem multiple times .... blah, blah, blah.
#25 ·
Yeah I'm going to get a yellow Optima battery for my whip when the Toyota factory dies on me again. I had them replace it 4 times and they said they won't do it again because there must be something wrong with my car... which isn't true. Toyota just supplies crappy batteries.
