Hi. I have a 1998 Toyota Camry LE (4 cylinder).
I recently took the car to a Toyota dealership for an oil change. Because the timing belt or the drive belt (I forget which one) was found to have cracks, and because the car has about 59000 miles on it, I was advised to replace both the timing belt and the drive belt. The dealership will charge $480 for this replacement.
I called some independent repair shops for additional estimates, and these shops have told me that the timing belt and the water pump work together and that, therefore, the water pump should be replaced as well. And, if the water pump is replaced, then a coolant flush has to be performed also.
Obviously, replacing the water pump and performing the coolant flush will incur additional costs.
So, do I really have to replace the water pump and perform the coolant flush? Or are these repair shops trying to rip me off?
Thank you for any comments.
