Hey folks, I purchased a 2014 Camry SE recently and the whole bluetooth interface is extremely glitchy on the vehicle. For instance, when you get inside the car and turn it on, the bluetooth takes forever to connect to my phone, but mostly doesn't connect unless I go into Setup-Bluetooth-Disconnect my phone and connect it again.
Second, the incoming calls on the car speakers sound horrible. There's this "sound-distortion" that comes out of the speakers and the call quality is not very clear.
On our 2012 Camry, everything is perfect. As soon as you get inside the car and turn it on, the bluetooth connects instantly (and I really do mean that - takes max. of 5 sec for it to connect), starts playing the song where it left off, and the call quality is crystal clear using the car bluetooth system.
Spoke to the dealer and apparently Toyota is aware of this problem in the new Camrys' and they are going to be sending out a "flash fix" in the near future.
I am just curious, is anyone else with a 2014 Camry SE/XLE having similar problems?
Just an edit, I had tested out a 2014 LE at the dealership - which has the same interface/software as the 2012 LE (they look alike atleast..) and the bluetooth system and the functions work flawlessly, just like on our 2012 LE....so I am guessing it may be a problem with the interface/software that is found in the SE/XLE models (with GPS) which is different from the LE model....
