I am in the middle of a Gen 3 brake pad and rotor replacement. I have a question regarding the sliding pins on the caliper. these are the pins that hold the active portion of the caliper to the caliper mounting bracket.
It was recommended on the forum to remove and grease these with high temperature grease. Reference forum: http://www.toyotanation.com/forum/showthread.php?t=163537
What is the function of these pins?
How do they reinstall? there is a nut that you have to keep from moving, when you remove the bolt. Is there any special alignment or depth, or other requirement that I will get into if I remove the pins for regressing?
Why is regressing important?
Is any high temp grease allowed?
In another part of the job, I am replacing wheel studs, as some broke off during removal. I might need to seat these all the way prior to putting on the wheel. Problem is they hub rotates (both wheels off). Any way to keep the hub from rotating while trying to torque the heck out of these?
Thanks,
Ted
Thanks,
Ted
