Squealing sounds up front when braking alerted us to possible brake pad wear. In replacing the pads we found that on the front passenger side both inner and outer pads were nearly completely worn. Drivers side was closer to 4-5mm remaining on pads. The vehicle is on 08 HiHy and has been ours since 80k miles and now has about 260k. We love the car and want to keep it running.
Checked the caliper pins and they have always been lubed and move smoothly. So no issues there. However the passenger side caliper seems to have a failed ring, with some brake fluid leaking past the ring into boot. Also, after depressing and letting off of the brake, the front passenger wheel doesn't spin freely as the driver's side. So it seems the caliper on that side isn't releasing as it should. We would like to replace both calipers and give new life to the brakes.
We don't have access to techstream to flush the brake fluid. Is there a way to DIY the caliper installation at home, limp the vehicle to a dealer so they can flush the brakes with techstream? Would I be able to drive the vehicle to the dealer for the flush? Is there any way, short of buying techstream, for me to diy a caliper change?
