Brake question?
2.1K views 16 replies 10 participants last post by  cuzman
Well today I was coming home in the fast lane at about 90mph when I look up past the truck in front of my and see a Chevy SUV spin!! :eek: About 50 feet in front of me is an early 90's F-150, he locks his and I jump on my brakes with every bit of strength my leg will give me!!:eek: the F-150 just barely missed the suv and I stopped before hitting the F-150. At first I was really impressed with the way my car stopped but then I was worried!! From my understanding when a non-ABS braking system is up to par it should be able to lock the wheels up at full braking power. (Even though you really don't want the brakes to lock up in a panic braking situation, bacause it increases stopping distance.) My question is what could keep my brakes from being at 100% I have the GT-s rear disc conversion including brake booster, master cylinder, new rear lines, proportioning valve, pads and rotors that are no more then 3 months old and all new Toyota DOT 3 brake fluid!! The olny thing that hasn't beeen changed is the hard brake lines!! Am I worrying too much or is there a problem in my braking system?
Flashmn said:
Locking the brakes is actually worse, because 1) you lose control 2)a rotating tire slows down better than a locked one.
He knows
try reading his post first, and yes you should be able to lock your wheels.
#11 ·
yes you should be able to flat spot your tires on a non abs car if you have everything correct in the braking system.. No you should not lock up your brakes on a non abs braking sustem you should strive for a 90% braking situation since you still can maintain some control over steering. I had to do this every two years for a long time until abs became standard on patrol cars and yes boys I was one of the guys chasing you down in the crown victorias and chevy caprices. We had to practice every other year with brand new cars on a track. I did not mind getting paid overtime for the duty. The track instructor told us that tires averaged about 300 miles a set.
Sounds like air in the lines to me, who blead your brakes?
I bled my own brakes with the help of friend @ work twice to make sure all of the air was out!!
I'm moving to GA if speed limits are 90mph there
It is the speed limit as long as you have you radar detector up and cops have something else better to do!!
#13 ·
Try bleeding the brakes again and make sure all the bolts are tight as not to let air back in or fluid out...Might be worth checking your proportioning valve but if anything somthing front or back sould be locked up under full pedal force unless your a midget..lol no offence guys
#14 ·
I can't lock them up at high speed with my new tires. They used to lock up easy with the stock size tire. But I also can't burn out with these tires anymore either. to grippy and the lack of power.
I was bored one night and I was trying it out. since I need to get a feel of what these tires can do. they increased my stopping power tremendously! :D
Mate whats your tyer size cant remember what you got as i was following you other post just before..ps go the 20v..lol ..bigger tyers will stop you from burn outs etc due to the grip facter..as your car has...im gessing std front discs this will place a lot more load on your braking system..more than intended..hence you will need more pressure to lock em up!but the bottom line is they sould still lock if only just!!!!also after a few atemps the pads will get hot and fade making it almost impossible to lock em ..so try once at a time with a break in between to let them cool ...hope this helps..got spec on ya front setup
#16 · (Edited)
they will lock once you get going slow but I can't lock them at high speed
the orginal tires were 175/70 r13 they locked EASY!
205/45 r16
you need to think that with such a large tire on the car when I got it when I hit the breaks all that weight going to the front of the car causes the tires to deform losing their traction causing them to lock. good way to see that is go up to your car and push on the side and the tires will deform and the car will move. With these new tires I can't sit in the car and shake it because the tires have almost no movement to them because they are low profile. when I hit the breaks the tires keep more of their shape keeping their traction stopping them from locking up and allowing me to hit the harder shortening my stopping distance. Alot of people think I went and bought a set of rims for the looks where I actually did it for the preformance aspect.
the stock breaks are MORE than sufficnant to stop the car. Just because you don't have abs doesn't mean they will always lock when hit hard. Comes down to alot of factors such as the tires (how the tread life is, traction and such), the strength of the caliper and the condtion of the pads and rotors or drums. The road conditions. and blah blah blah...
and I hit them randomly on a country road late at night doin about 140 km/h and they didn't lock then I tried from about 70 km.h to a dead stop and they locked up near the end.
#17 ·
Yer sound bout right as i had a car that did the same thing ..it stoped sweet would'nt lock at high speed ...thats why performance cars have bigger brakes...to over come the
a.speed
b grip tyer/road
c. heat build up
d. yer well ya know!
any way as long as it hauls up in a good time ..who whants to lock up at over 60 mph anyway not me!!
Are you guys in k's or mph ican covert but wher in k's..came in bout 1970
ps how much was ya shifter and from where
