Brown goop on spark plug threads
637 views 14 replies 7 participants last post by  Dante's Taco
Just changed the plugs at 100k. OEM service info does not mention putting anything on the threads. But the factory threads came out with this brown goop all over them?
What's on the threads came from the combustion chamber. Spark plug gaskets were still well seated and sealed, so they did not leak... Residue is somewhat oily, mostly on #1 and #2 spark plug threads. Does it consume a bit of engine oil? Have you been running on 0W-16 instead of 0W-20 or 5W-30, and at how many miles between oil change intervals?
The boot doesn't go to the very bottom of the spark plug and would be dry even if a small amount of oil has seeped from the valve cover. Poke a rag down the tube with a stick while you hold the end of the rag so you can pull it out after wiping the bottom of the sparkplug tube....only if you want to know why oil got on the spark plug threads. If it was from the combustion chamber, the oil would be burned up.
What is your opinion on running 5w-30?
Some Camry owners down south and in Australia already use synthetic 5W-30... Which state are you in?
I have a 2020 le Camry a25a engine I have used 5w30 Motull oil since I have had 250 miles on the car. Engine runs much quieter. I no issues with any check engine lights coming on. Except for when I had experienced the bad fuel injector 28000 miles approximately.
corrected spelling error 5/14/2024
Thanks
CJ
I've used Mobil 1 5W-30 in my 2018 LE 4 cyl for 33,000 miles during the spring, summer and fall in central interior California. No hint of trouble at all and I was really surprised I still get 42-43 MPG at a steady 70 MPH on level ground just like I did with 0W-16 factory fill. I use Toyota 0W-20 Nov. - March since we have quite a few mornings when temps are in the 30's.
Font Screenshot Number Parallel Rectangle
Camry Owner's Manual (Feb 21 - Current) - Toyota Australia
Font Parallel Document Circle Publication
540 RAT - Tech Facts, NOT Myths (wordpress.com)
#14 · (Edited)
Yeah, maybe...add a little STP to try and prevent seal leakage and ask again in another 60,000 miles. Those gaps look pretty good, by the way. Oil is very tough. Could be an application by whoever installed the plugs. Once I tried to set fire to a puddle of motor oil on the ground with a propane torch and it only soaked into the concrete without burning. Nothing to worry about, OK.
