This has been happening for a while now. When jumping off the highway and coasting up the exit, the engine rpm's kick in and act as a brake. That's when this hot oil smell occurs. No throttle is being used, so could it be a vacuum issue letting vapors out? My intake manifold looks like it has some oil spray on it from the head, but my head gasket is still doing ok. Not sure, but it is a little alarming and quite stinky. Not sure if you guys have ever used a gas soaked rag to start a diesel tractor, and you get that horrid smell. Well that's what this smells like.
