Buzzing behind speedometer
4.4K views 10 replies 8 participants last post by  bibek28jan
I've noticed over the last couple of days when I put the car into D or R, and take my foot off the brake, there is a buzzing noise somewhere behind the speedometer. Has anyone else experienced this? Any ideas? I own a 2018 Camry SE.
Similar problem in our 2009 highlander. Turned out to be a check valve in the brake booster. Was fixed under warranty, never came back. This is the TSB#: T-SB-0229-09 regarding similar issue for the 2008- 2010 highlander. It could be the same problem. Just chiming in and hope this TSB helps for fast diagnosis.
#8 · (Edited)
Same here
I came back to this thread because I remember seeing and just started hearing the same noise. The idea about the brake booster makes sense since there seems to be a relationship between the buzzing noise and using the "hold" feature. If I hold the pedal manually sometimes its quiet, but as soon as I push it far enough for the hold feature and let up it starts buzzing. Once you drive for a little the buzzing subsides.
I'm at work now but when I get home I will listen to the booster check valve with a stethoscope and see if I can verify that's it. (Cant believe I'm doing this on a brand new car...)
#11 ·
Hi, has anyone able to get this fixed. Has this anything to do with the new TSB that came out regarding the Brake Assist vacuum pump???
Toyota says camry produced between Oct 5 to Nov 3 are affected. Mine was manufactured in Nov 17, does not say exact date though. Can someone else post the date of manufacture also .
