Caliper Slide Pin with Bushing Placement - Top vs Bottom
42K views 29 replies 12 participants last post by  CRenz
Hello,
New member. Be gentle.:) This site has been extremely helpful for information in getting my recently purchased 2003 Highlander up to snuff. Thanks to everyone here. It's running great.
My question is what is the correct placement of the one front caliper slide pin that has the rubber bushing on it: top or bottom? If your answer is leading or trailing then which is that if the assembly is on the front of the wheel?
I'll do my best Joe Friday. Here are the facts:
-1MZ-FE 3.0L Engine (V6)
-2003 model year
-Front wheel drive with disc brakes and no real signs of uneven front pad wear on old front pads.
-The brake assemblies for the front wheels are on the front side of the rotor
-I just completed putting new rotors and ceramic pads on all four wheels. I cleaned/lubed everything thoroughly including pins and their channels.
-I drove it to bed the pads and everything functions well. No issues or noises so far.
-I had known about the asymmetrical pins and made note of where the pin with the bushing was positioned as I went along. It was on the top location on both sides.
-I know the previous owner so have the service records and to the best of my knowledge the last brake job was done by a local Toyota dealer (they could have put the pins in the incorrect holes obviously).
-The pins are slightly different lengths.
-The pins are not identical. The 2nd has no bushing, of course.
-I'm not talking about the accordion like dust protectors which is a common confusion with this question.
-The reason I had to replace the barely worn but old pads was that the both of the outside front pads were missing their top support plates which made the pads loose when the brakes were not applied causing a rattle on bumps. So, either the Toyota dealer didn't install the support plates in the same location on both sides, they fell out coincidentally, or the possibly incorrect position placement of the slide pins exerted some force that disintegrated/broke/loosened them hence my curiosity on this.
All the YouTube videos I've found gloss over this and just say to remove and clean one pin at a time which I did. They don't mention correct position placement. My Hayne's and Chilton's manuals make no mention of proper placement and I do not have access to a FSM for this model year. But I've seen parts diagrams and FSM screenshots that conflict with each other. There are many threads here and elsewhere that I have researched. There seems to be no consensus.
-I've read that the pin placements 6 and 4 cylinder engines are different (with the V6 having it in the top hole) which would account for all the differing answers. These were for Toyota vehicles other than the Highlander (e.g. Camry).
-I've read that it doesn't matter as long as the pins move freely.
-I've read the placement of this pin helps dampen vibration.
-I've read improper placement of the bushing pin can lead to uneven wear patterns.
-I've read that the pin locations have changed over the years.
I've attached a stock picture I found online to show the difference in the pins (silver pin with missing bushing is on the right). Sorry for the long post. Just wanted to provide all pertinent info.
Thanks.
Edit: Fixed typos.
2003 V6 AWD 369k miles. Original owner and chief grease monkey.
osgood:
What, is this some sort of a test? Ha-ha.
I've replaced brakes a zillion times on my '03 and quite frankly I never noticed. I think my pins are the same for both. I don't know.....and somehow it probably does not matter. Good luck and thanks for posting.
Haya.... 😎
(Hayabusafalcon) translated means diving falcon-falcon. Goalie reference. Always out of position?!🏒
Ha! It's not a test. 😂 But you passed anyway! Thanks for the response. I think you're right that their position doesn't really matter in the end. I got 335K and 17 years out of my old Chevy so I just like to become very familiar with what I have at the time. Often to a fault. I did find a couple of people with the Lexus RX version of the 2003 Highlander with the same V6 engine saying the bushing pin goes in the top. Last thing I'll do is go to the local library and see if they still have factory service manuals like they used to when I was a young grease monkey. Other than that, I'll just do my routine inspections and keep an eye on it. I'll switch them in the unlikely event I have problems. Will definitely put new pins in next time (hopefully 75K more or so!).
CR, thanks! I've seen similar scans of FSM that show that as well and why I was considering switching positions from how they were on mine. Interestingly, I found this scan (most likely for a 1999 Camry though so take that with a grain of salt) that specifically excludes the 1MZ-FE in a note and says to put it on the top side.
Hayabusafalcon, nope, not big into hockey, but I remember the name Chris Osgood. It's actually just an old time radio character reference. I'll think about getting a subscription to the sites CR mentioned at some point. Library only had the Chilton's and Mitchell's. Didn't have either the year or detail I needed. Thanks.
#9 · (Edited)
ossy:
What? not a big fan? Well that probably means you are not a Penguins fan either and have no idea why I added "Dammed Sindy (Sidney) Crosby". We don't like that player. Never have.
The reference was for 2009 game seven Stanley Cup finals Detroit vs Pittsburg. Both Chris Osgood and Ty Conklin were with the Wings at the time. (Conklin had been with the Penguins previously.) Those nasty Penguins beat the Wings 3-2 in OT to spoil the chance of a repeat Stanley Cup for the Wings. Shoot.
That's amazing that the random username I chose ended up being the last names of two NHL players! Very funny.
I noticed something else interesting about the caliper pin positions during my research.
On all the diagrams of Toyota rear wheel disc brakes I've seen, the slide pin with the bushing is shown as the lead pin. It's the lead pin because the rear brake assemblies (caliper & brackets) are usually mounted on the back of the rotors (facing the rear bumper) thus making the so-called 'bottom' pin be the lead pin. This is the exact opposite of the front (brake assembly mounted on front of rotor) where the lead pin is usually shown to be non-bushing slide pin.
For consistency, if you define the terms as leading and trailing pins (top and bottom are too relative to brake assembly mounting locations) as:
Leading Pin = the pin that a fixed imaginary point on a rotor first passes after during its normal forward rotation
Trailing Pin = the pin that a fixed imaginary point on a rotor last passes during its normal forward rotation
I don't drive very far in reverse so that's not worth discussing. 😂
Thanks for confirming the different pin lengths, Riick. It's subtle but definitely there. The non-bushing pin also has flats while the bushing pin is completely round. I wish I had measured the pin diameters and bore diameters while I had everything apart but was just wanting to be done since it was getting late. I do feel better about my decision to leave them in the leading pin positions where I found them in originally. It's a one owner vehicle with one brake job done by a Toyota dealer so that's only one opportunity for them to have been switched. If any place was most likely to be familiar with this and prevent it by either only servicing one pin at a time or at least putting them back correctly, I'd hope it would be there.
#13 ·
I'm with Haya, I don't think it matters. I try to keep mine in the right position, but sometimes I kick over all of my neatly lined up parts. I've even put that bushing pin in without the bushing. Never noticed a difference. Does anyone here know what is the purpose of that bushing and flat side?
OE, thanks. I know what you are talking but I think Mgeorge was talking about the flats on the pin itself. The non-bushing pin has them. The bushing pin is perfectly round with no flats. You can just see them difference if you enlarge the pic on my original post. I can confirm that mine had the flats too as I had it in my hand.
#16 ·
Oh, gotcha.. The flats on the pins like that is usually to prevent hydraulic lock with the grease . Pressing a completely round pin into a (blind) close fitting hole... You need passageways for the lube to move around since it isn't compressible. But that wouldn't explain why there are only flats on one of them either.
And about your original question about "which one goes where?"... I've had mine apart a number of times, but I'm sorry I don't remember why they are different or which one goes where. None of my pics are detailed enough to tell.
#20 ·
Thanks for your answer. I've since discovered that the slide pin with the rubber bushing goes on the bottom. This is how it's shown in the Chilton manual diagram. There are a few opinions as to the function of the bushing but many of them have to do with controlling that the caliper works correctly.
#21 ·
I think the only way to definitively solve this mystery of the conflicting manual pictures and YouTube videos is to buy a new old stock, never driven or serviced 1st Generation 1MZ-FE V6 and also find a new old stock 4 cylinder where both have been in storage for ~20 years and never touched. Should be easy to find those nowadays...probably in someone's barn somewhere. 😂😂 Then disassemble the brakes on both. It would have to be filmed like Al Capone's vault opening was, of course. 😂 For an update, I've been driving my 2003 V6 FWD with the pin on the top for a few thousand miles since I started this thread with no discernible effects...yet. I just left it where I found it as the original owner had it exclusively serviced by a Toyota dealer (which admittedly doesn't mean much).
#23 ·
I drive a Corolla Se 2018. Recently had pads and rotors replaced by an independent shop mechanic. Could be nerves and stresses since I asked him what grease he used for slider pins and got a vague answer “all we use are synthetics” Off course when I disassembled the left rear pins I found both pins had the rubber bushings (top and bottom) That is odd, unless he mixed them up from the right rear calliper. Before I remove rear right pins can anyone in this great forum point out the correct part for assembly?.
#25 ·
He mixed them up, maybe. I am not certain about the Corolla brake setup, but both my 2007 highlander and 2015 Lexus Rx350 has solid caliper slide pins on the top and slide pins with rubber on the bottom. I assume that is how Toyota does its calipers across the board on all models.
#30 ·
Great question, and one that’s easy to get wrong if you're not careful. On the 1993 Toyota Camry, the two caliper slide pins are indeed different, and their placement matters for proper brake function.
🔧 Pin Placement Details:
  • Pin with the rubber bushing (also called a vibration dampener or sleeve):
    • This pin typically goes on the bottom of the caliper bracket on the passenger side, and on the top on the driver’s side.
    • The bushing helps absorb vibration and allows for smoother caliper movement under braking.
  • Pin without the bushing (smooth pin):
    • Goes in the opposite position—top on passenger side, bottom on driver’s side.
🛠 Why the difference? Toyota designed it this way to help manage caliper movement and prevent uneven pad wear. The flat side on the pin helps guide the caliper’s motion and ensures it doesn’t bind.
Tips for reassembly:
  • Clean both pins thoroughly and apply high-temperature brake grease—but only the kind safe for rubber components.
  • Make sure the pins slide freely once installed.
  • If the rubber bushing looks swollen or cracked, it’s best to replace it. Using the wrong grease (like petroleum-based) can degrade it over time.
If you’re rebuilding both sides, it’s a good habit to remove and reinstall one pin at a time to avoid mix-ups.
(Found this via my Co-Pilot program in my own search of an answer, after looking at this and other chat threads and my Haynes Toyota Camry 92-95 All Models, that only had one photo Chapter 9-8 that was on the bottom, but without explanation. One YouTube video said to chalk one pin for each side and reassemble as originally found, but no explanation as to why. ) This Co-Pilot version make the most sense to me....and likely ok to switch the driver and passenger sides as long a one is up and the other down. Since this guidance says "Typically" goes on the bottom. Passenger side. "
