Can you adjust headlights left and right?
2 reading
5.5K views 4 replies 4 participants last post by  MarterH021
I have a 2014 highlander and I have adjusted the headlights up and down. I see there is a hole that’s says left and right adjustment, but I don’t see a gear that my screwdriver goes into. Does anyone know how to adjust the low beams left and right?
There's no adjustment left or right that I'm aware of. Have you read through your owners manuals? I guarantee it'd be mentioned there if it exists.
Some vehicles have headlights which do rotate according to the direction of the steering wheel, but only in sight increments and I'm not sure if those could be tweaked either..i do know a failed one looks. The light will bounce around inside the housing and people driving in front of you will undoubtedly not be happy at the bobbing lamp.
If your lights aren't aligning directly then your headlights are not installed correctly. Or, perhaps the hardware is becoming loose that bolt the housings in place . I've seen that too where the headlight might shift sightly left or right as a result. You can usually check by placing your hand on the headlights and push it in and try to pull it out. See if there's some wiggle. There shouldn't be.
Lots of places are selling aftermarket h11 bulbs that are not actually h11, but instead are mounted upside down (but they will press into the Keyed slot just fine). Only difference is one is meant to be in fog lights so it could end up being installed upside down. The light projecting from the headlight would look off probably.
First your led bulbs should be adjusted, and then turn the screws clockwise to adjust the headlight inwards and counterclockwise to adjust them outwards. The headlight beam should fall just to the right of the center tapeline. Next, block out the adjusted headlight and do the same vertical and horizontal adjustment on the other headlight. Fine-tune the adjustments. that's what i did, after that you can have a check of your cutoff line, they recommend 25 feet away from wall. Center of tire to wall. I replace mine with auxito led bulbs, check.
