Anyone know what the inlet and and outlet temps should be on the catalytic converter. 2015 Corolla s . At idle mine are at 850 inlet and 425 outlet. Running 60mph 1360 and 1100. Going from 0-60 at 5000rpm gets up to 1600 -1400
Inlets 840 outet 425 at idleThere is no precise temperature reading, they depend very much on the amount of exhaust going through the pipe when check. What you should be more concern with is the differences between the inlet and outlet, which tells you whether the cat is working or lot. In general, the outlet should be considerably higher when the cat is working.
