There are many different types of antennas you can change to out there...pretty much as long as the threaded portions are the same you can switch to whatever you want. If it's not an S2000's actual antenna, it's probably just one of those "stubby" universal ones that is simply shorter that you can find all over eBay...I don't know that you actually need one specifically from an S2000. I used to have one of those, though the reception was terrible because it was so short. I have instead a paint-matched fin-style one like you tend to see on BMWs from the last 10 or so years.
As for searching on the forum, at the top right of the screen is a header full of links that I'm sure you're familiar with. One says "Search" and has a drop arrow next to it. From there you can search for a certain set of keywords, or you can go to an advanced search that lets you use keywords, search thread titles, search the text in entire threads, or search a specific section only (a good way to search the "For Sale" section of the forum without pulling up every single thread on the forum that mentions the part you're looking for).
If you don't care all that much about your original antenna and want to do it the super cheap way, get a tire valve stem cap, and a pair of diagonal cutters. Clip your antenna right where it starts to go from thick to the thin, spiraled portion. Stick the stem cap on top of there and either wedge it down or even glue it if you want. Presto, quick and dirty, and cheap as free.
