Clay-like fluid in radiator
15K views 4 replies 5 participants last post by  Strokd_GE
I have a '96 Corolla, 4 cyl auto, with 148,000 miles. My coolant overflow tank and radiator has this really thick creamy brown colored mushy stuff in it,
almost like wet clay, even like dry clay in a few spots.
The radiator was recently changed and flushed. It was a few days afterward that I noticed.
I do leak oil somehow, and have never noticed a puddle. Could this be a sign of a blown headgasket? I'm not overheating and there's no white smoke out my tailpipe. Also, it doesn't appear that there is coolant leaking into my oil.
Is this a common problem on this age/mileage of Corolla?
What should I do?
Thanks for any advice.
The coolant/water you put in the car, drys out over time and leaves mineral deposits in the radiator. That clay your seeing, is a build up of the deposits.
Flush your system completely and run water/rad flush, then flush again, then refill when the water is clean in your engine bay.
that clay like description is exactly what you find when oil leaks into the cooling system. Head gasket failure is not ALWAYS through the combustion chamber.
Start with a good reverse flush with a commercial cleaning product of your choice. You have to use a cleaner to get any residual oil out of the cooling system. You cant do it with straight water. If it stays away you'll be OK, but if it comes back, its head gasket time. Dont forget to clean the reservoir too.
-SP
