Clicking noise while turning steering 2016 camry
1 reading
18K views 10 replies 4 participants last post by  TonyTech75
Anyone have this issue? I have 2016 camry 4 cyl have roughly 2300 miles and I'm noticing a click click while turning the steering wheel left or right while stationary and vehicle running sounds like it's coming from under the dash.
I've seen there is a tsb for other year camry intermediate shaft issue, my vehicle is lowered on eibach Springs and would hate to take back to dealer and have them blame it on the springs in a vehicle that has only 2,500 miles.
your issue is probally specific to your car these things are massed produced and literally anything can happen from the factory, if you can't feel it at the strut mounts it isn't from the lowering springs, and therefore covered by the warranty. if dealership says it is because of the springs then ask why you can't feel it at the spring but can from driver's seat.
#8 · (Edited)
Unfortunately even though we all know it doesn't cause the problem don't mean a Dealership is gonna take your word it dosnt. Toyota Dealerships don't want to warranty anything.
I already know my lowering springs aren't causing the clicking noise.
I'm looking for others with similar year that have had a dealer fix this with a tsb so I have something to fall back on if not then worst case I will remove springs prior to taking it back for service.
With my 13 tundra they use a check off sheet before doing any work.
If it's lifted? is there any signs off road use? etc
Thank you
#9 ·
I have a 2016 Camry 4-cylinder XSE and am experiencing the exact same thing. The clicking noise began shortly after installing my Eibach Pro Kit lowering springs. When I took my car in for its 6-month service last month, I asked them to inspect my front steering and suspension to help identify what was causing the noise. They were unable to conclude anything and told me that if it's due to the lowering springs, there wasn't anything they could do to help.
