I went over the suspension sticky thread, and I also used the search function but I haven't found the answer to a question: Which is the most street friendly coilovers available for the 6th gen camry? What I mean by street friendly is a coilover which wont knock your teeth fillings out with every bump you hit, and will let you drive up a semi steep driveway without scraping the bottom of your car. Yes, I know coilovers are adjustable for height and firmness but I also know that there are some coilovers, even adjusted to its tallest and softest settings would still be considered too aggressive for me. This is my daily driver and no I dont track the car. I just feel like it has a bit too much ugly wheel gap, and a bit too soft on the spring and shocks.
Ideally, I would like to have a 1.25" drop all around, and on the softest settings feel only moderately tighter than the stock SE suspension. Is there a set that comes closest to this description??? I want to increase handling characteristics but still handle the rough roads of NY and NJ while dealing with all sorts of foul weather we get. I know swapping to shorter springs is an option, but I have read multiple threads with drivers bashing a swap to shorter springs on stock struts. I want to stay faaaar away from the "floating boat" and "deep bouncing" feeling that you get when the shocks cant handle the increased pressure from short springs.
I heard the TEIN BASIC/BASIS are excellent coilovers for daily driving but these are not available for our car unfortunately.
