Hello folks,
First time poster here. I am more familiar with older Toyotas (early 90s and before) than I am the newer ones. My wife's 2000 Camry has had me baffled for weeks. We even had several mechanics look at it.
The engine would miss at random times. We had a tune up done including plugs, wires, fuel filter, one marginal injector, the EGR valve (twice), the EGR tube assembly under the valve, they checked the coils, plus over this period of time, we've run run 3-4 tanks of premium gas with different fuel cleaners including Lucas, Techron, and SeaFoam. Three different mechanics looked at the car and would declare success because they wouldn't drive the car long enough for the symptoms to reappear is all we can think - I know intermittent problems are a bear to deal with.
In general, the car would idle okay and there were times it would be better and others worse. It was a devil to deal with - sometimes it would be ok hot and others ok cold. I seemed to notice it the most easily in 2nd or 3rd gear at about 1800-2500 RPM.
The car went to the Toyota dealer 7 times (literally) until I gave up on them.
Starting on Monday, I noticed the car was getting sluggish more frequently but no check engine light. Today, my wife and I took it for a drive and the check engine light came on plus it ran rough - even at idle a few times - usually it was okay at idle. It also didn't matter whether I clamped off the EGR vacuum line or not. I could feel it missing several times per minute over the course of about 20-30 minutes until we got home.
Once home, I hooked up my scanner and got P0300, P0302, P0304 and P0306. I did some digging and noticed guys posting about problems darned near identical to ours and they figured out it was the fuel injection pressure regulator and that there might be one for each bank.
Now here is where I am a bit lost - where are they? In digging at Autozone and in my Haynes manual, I see a fuel regulator on the fuel pump but nothing on the fuel rails. Online, a guy had pointed to a plastic capped end of the back rail and said that was the fuel injection pressure regulator but I can't find anything to confirm that plus guys talk about pulling a vacuum line to see if fuel is leaking into it and I don't see a vacuum line on/near that cap.
So, I have two questions for you gurus - where is the fuel injection pressure regulator for bank 2 (cylinders 2, 4 and 6) ---- or am i barking up the wrong tree?
Thank you in advance!
