ALL OIL QUESTIONS WILL BE IN THIS THREAD.
Scotty Kilmer. Such an informative guy. Thank you.It's not rocket science, many vids, follow Scottie Kilmer on You Tube. A Haynes manual and $200 in tools, Harbor Freight is awesome, save your money. Hundreds of how-to vids out there.
Exactly. Can't trust mechanics, especially the employees that get paid a low hourly wage.No one touches my Oil. DIY'ing my Oil for 37-years*. Friends have related too many horror stories about all the many variations on all the IDIOTIC things "mechanics" can do to ruin your day, your engine and your driveway from crazy oil-change mishaps!
*Except for 1991, when I allowed myself to be suckered by the Dealership into "free oil changes for life" when I bought my new Toyota Pick-up. They never said whose lifetime-- mine or the truck's. On the second "free" oil change, I checked right after-- he shorted me a full Qt. on a 4-Qt. system. That's a Dealership cheating me by 25% and who knows if the slob changed my filter? Never went back.
I employ genuine OEM Toyota Filters, change the OEM drain bolt Gasket each time, Mobile-1 Full Synthetic.
Thank you for sharing. I will most likely use 0w-16. And yes, usually 'free' comes with catches, usually poor service.The last new truck I bought was in 1989, never went back for service because of the long drive.
I even fixed (what would have been) a warranty brake rotor machining job myself, to avoid making the two trips since I needed the car at home.
Forget about looking for the too-light 0W8 oil, it's not good for your car!
One of the things I like about buying used is avoiding any "free" service offers and warrany-related hassles.
My 2015 drain plug never had a washer but I bought it used and it hasn't leaked a drop in five years.
I did my own trans fluid change at 23k, nine quarts of Toyota fluid for peace of mind.
I replaced 1.5gal of the coolant with Toyota's extra long life coolant at around the same time, better early than late.
I use 10W30 instead of the recommended 0W20, it doesn't rattle upon start-up any more and the 10W30 is good down to zero F. I change the oil annually after each 4.5k miles and replace the Toyota filter every other time. The weather here doesn't go below 30F so the filter and the oil's "winter" weight are less critical.
Thank you. I appreciate you taking the time!Oil: Open Manual PDF, and search oil. it should list how much and what weight. Go to store and pick it up.
Filter: https://autoparts.toyota.com/products/category/parts
For the powertrain warranty, just dump the cheapest spec oil you can buy at the Severe OCI and some toyota filters.
Done!
The Car Care Nut is a great resource. Thank you.Use the Viscosity of the oil that your manual says. Mobil 1 is always safe. Toyota filters are inexpensive so I just go with OEM. Toyota’s free services used to be a filter change every service but oil change every other. Check your manual to see if it’s still true! I want my oil changed every service. The first service I like to have done is at 1,000 miles, but I keep my toyotas 300,000 plus miles. Keep in mind Suggested services are made to get you past the warranty period. Check out THE CAR CARE NUT on line.
Solara. What a classic beauty.I've have had my oil changed at the dealership and at local gas stations in the past. They both presented an elaborate display of high end motor oil cans at their establishments. This gave the impression the customer was getting only the highest quality oil. When I changed the oil myself, I noticed an increase in gas mileage. Evidently, the engine was running smoother and thereby increasing mileage. I have a Solara, but I highly recommend changing the oil yourself regardless of which model you own. View attachment 426472
Same, Lots of money saved, lots learned and I am satisfied the person who did the job cares about the car and is doing the job right. I have found only 2 downsides to doing all your own work. First, no warranties on your own work, if a shop does your timing belt job and something goes wrong, they owe you a new engine. If I do the job and something goes wrong, it is on me. Which I accept. The second downside, people notice you are good at working on cars, All my family and friends come to me to work on their cars. Neighbors too. For the neighbors I usually tell them, I will not fix it for you but I will be happy to help you figure out the problem and help you to fix it.Nobody touches my Cars unless it's tires
Nobody
Anything another human can do,you can do
Probably better ,with better parts ,and less money
I'm 57,granted the day is coming I won't be able to
Then it's going to be the younger kid next door or something lol
Never let your car leave your sight
Yes I tend to trust myself over other people and it hasn't gotten any easier or better. Just read some of the horror stories I try and do all the maintenance possible I can....I've have had my oil changed at the dealership and at local gas stations in the past. They both presented an elaborate display of high end motor oil cans at their establishments. This gave the impression the customer was getting only the highest quality oil. When I changed the oil myself, I noticed an increase in gas mileage. Evidently, the engine was running smoother and thereby increasing mileage. I have a Solara, but I highly recommend changing the oil yourself regardless of which model you own. View attachment 426472
It's 0w-8 that is required, and not too many aftermarket choices that are readily available for regular hybrids.Oil: Open Manual PDF, and search oil. it should list how much and what weight. Go to store and pick it up.
Done!
