So I have had this coolant leak coming out of the rear of the engine for a while. I've been troubleshooting but finally found this when removing the intake plenum with the help of a mechanic.
Coolant in the engine valley
This is my project truck and I inherited it with a lot of deferred maintenance. I got it running pretty well but had a bit of coolant smell and it had coolant dripping out of the rear of the engine sometimes. Anyway, after testing compression (203, 202, 198, 200, 208, 195) and confirming there was no exhaust gas in the coolant, I decided to endure the expense of changing the timing belt and water pump as well as new valve cover gaskets. The water pump change didn't solve the coolant leak problem although I knew the water pump had a slight dribble.
Incidentally, the intake plenum was a bear to get off. It was corroded to the same stud exactly like the guy in this video experienced. The mechanic I had outsourced this work to called me twice trying to quit as they didn't want to proceed further for fear of breaking the stud. I went up to the shop and asked the guy to borrow his slide hammer and hit on it much harder than he was likely to have tried and got it free. That is the point we are at now and you can see the video of what it looks like in there.
- Do you think this coolant is all escaping through the gasket? I see no evidence of compromise on that coolant bypass pipe.
- What would you do about all that sludge in there?
- What else would you recommend at this point?
