Corolla 1zz-fe engine installation
2.6K views 2 replies 3 participants last post by  tdi200
I want to change the engine Corolla 2000 5E-FE
The installation of a new engine for the 2004 Corolla 1zz-fe
What are the parameters required to do this?
I need an explanation, pictures of the crisis, or a video
i have done the swap its very easy, u will use the original 2001 harness,
i even used the original 2001 harness, intake manifold, and exhaust manifold from original engine . The entire long block is the same. basically, doing is swapping the long block. Carry sensors, intake, exhaust, and belt drive accessories over from the old motor to the new one.
Only sensors carried over from old engine is the temp sensor on the driver's side of the head and the knock sensor (knock sensor of corolla 2003-2008 in the block is not the same (1 wire for 8th Gen vs. 2 wire for 9th Gen Corolla)
move the old fuel rail over use the metal coolant hose from the old engine that runs under the intake. And obviously move the intake manifold over as well and swap engine mount bracket
