Ok so I acquired an 06 highlander with the 3.3l from a relative. It had a misfire due to rats chewing threw the injector wiring harness on #5. Replace the harness swapped injectors around, swapped coil packs around, spark plug looks fine and I’m still getting the misfire on that cylinder. I thought maybe I wired it up wrong but it did the same thing once I flipped the wires. Put them back to the original way I had them and both wires are getting power so I’m completely lost. Maybe someone could give me advice on what else to check or maybe have a link to an oem wiring harness. I bought 2 pig tales from Napa.
