87, 22R, auto, 2WD, carb engine. I turn the key and 1 or 2 seconds later it turns over and starts. I want to test the starter relay first but I can't find it. I've looked on the fender in the engine bay and in the fuse box next to the battery and in the cab in the drivers side fuse panel. I found one component located above the fuse box in the cab that look promising. This part was blue. But, after unplugging it from it's harness and turning the key, the truck still turned over and started. Does anybody know where the starter relay is? Or if it even has a starter relay?
