diffence between USDM and JDM 3sgte motors
36K views 16 replies 11 participants last post by  Goopi
im wondering if you guys could tell me what is different between the two motors that makes the USDM have 200hp and the JDM have 225HP? and then theres a later JDM 3sgte motor with 245hp? what is different between the motors? how do you know which JDM motor comes from which car?
thanks for the help
thanks for the help
the 2nd Gen 3s-gte comes with a ceramic turbine blades. The 3rd Gen which is the 245hp'er has a CT20B turbo. The JDM motors also doesnt have any of the egr system the USDM motor has. The Head are the same on the 2nd JDM and USDM motors; (i.e shim on top, big port small runners, multi runner set up, TVIS, and basically the same intake plenium). While the 3rd Gen has small port, big runners, shim under buckets, Roundish intake plenium, alittle more agressive cams, MAP sensor ( instead of maf thats found on the 2nd gens), High boost setting 12psi (instead of 7psi), fuel cut is at 19psi, bigger port for water and oil, and doesnt seem to have the issues of head gaskets. Thats pretty much what I remember off the top of my head.
Hope this helps...
hmm ok. so let me see if i got this right:
1. the only difference between Gen2 usdms and jdms is the turbos?
2. the difference between the jdm gen 2 and jdm gen3 is the turbo and a more agressive head? whats the difference between a maf and a map? thanks for the help guys.
Reactions: scottmirenda10
#17 · (Edited)
Bump for misleading information.
All mr2's come with map sensors, but they operate on AFM's for USDM models and the 93+ JDM ones have MAF's. The map sensors are for fuel cut, which activates at roughly 13 psi, but later increased to 17 psi for he 93+ models. I know this goes for USDM models for sure, but quiet sure about JDM models.
BTW, just because this thread still pops up on Google, there are many differences between USDM and JDM.
alright. cool thanks. one last Q, did either the 2nd or 3rd gen jdm 3s-tge engines come stock with LSDs? thanks
#14 · (Edited)
The 3rd Gen's cooling passages and head gasket also differ from the previous generations. IIRC, some people were having issues with certain HKS head gaskets because they were designed closer to that of the 3rd gen's specs. This caused the head gasket to not line up with the factory drilled 3S-GE, 1st and 2nd gen 3S-GTE, and certain 5S-FE blocks.
