Difference 4AF & 4AFE
1 reading
10K views 13 replies 6 participants last post by  05_GTO
How do you know if you have a 4AF or 4AFE engine?
#9 ·
It is a 4-AF is a carburated engine. It still get about 27 mpg but I am trying to fix a running rough
problem only after the engine is warmed up. Sound like it mis firing. This only occurs when the engine
is under load and not in park. The mechanic say it needs a carb but I want to make sure it is not that
first by checking timing and other things. It has about 178K miles on it. Not sure how long the carb's
work on this baby's.
#14 ·
Mine does the same thing. My first thought is the idle needs to be turned up. Or the carb needs rebuilt, I for one will not rebuild a carb, too much work. I did however clean it yesterday and I hope that will calm it down some... I don't touch carbs so I would like to turn up the idle some to see if that helps but I don't know how.
