How does one know what rear end is in a truck, is it stamped somewhere. My new to me T100 revs really high, like 3K at 60mph. Someone said it’s probably because of what gear is in diff.
These are the ratios I show fer the stock ring gear fer the 1993 T-100 4WD.
Rear Axle, (6 cylinder), 4x4, ABS, 4.46 ratio (MT)
Rear Axle, (6 cylinder), 4x4, ABS, 4.70 ratio
Rear Axle, (6 cylinder), 4x4, ABS, 4.90 ratio (AT)
Check all the groud wires in the engine bay.I think you'll find one going to one of the fenders that if corroded or loose can cause a jumpy tach.Actually I noticed the rpm’s jump around a lot. They can be at 2K and if I just touch the accelerator a bit it jumps up to 3K.
I will try and show it in video.
