Disable , Turn off tpms tire pressure monitoring system light 2005-2014 tacoma
86K views 29 replies 19 participants last post by  Djea3
Aloha everybody, Im new to toyota nation but ive been lurking for a while. now that im on here looking for help with some other issues I thought I would give back. Ive had several tacomas and everytime I get a new one the first things I do are turn off the door dinger and disable the TPMS light. Searching through to find the TPMS light disable, since I forgot how, I realized how tough it is to find for the proper year (2005-2006 is different procedure than 2007-2014) so here is the SUPER easy and quick way to disable that stupid thing! Several posts have been made about removing the hvac controls in the center of the dash and doing a bunch of stuff in there. No need brah! just take off the glove box. Up behind there to the far right is a white connector taped to the outside of a wire harness. here is the post by toydriver00 way back in 2006. He goes off and removes ALL this stuff behind the stereo but I dont see any reason to do all that.. Just ignore steps 1 through 12 and skip to step 13 and picture 3 to see the connector im talkng about.
http://www.toyotanation.com/forum/6...nd-generation-2005/124871-how-disable-2006-tire-pressure-monitoring-system.html
there is a blue wire in the connector. Just take some wire and strip it and jam it into the back of the connector with the blue wire. I used some electrical tape to make sure it doesnt come out. Next, he puts the other end to a ground, you can read all about it in his post. That works for a 2005-2006. However on 2007 and up, this wire requires +5V to turn the tpms light off. I used my voltmeter in there and just tested a bunch of wires and found one that gives 5v. if you look at pic 3 again, look at the bunch of wires furthest to the left of the picture. they go into a black connector that is between some big black plastic thing on the left (part of the foot heater?) and the big white panel with tons of plugs and wires (4X4 ECU?) on the right. Anyway, that plug has a blue wire as well, which happens to produce +5v. Just jam the other end of your stripped wire in the back of that plug so that it contacts the blue wire. Please test this wire first with your voltmeter to make sure its the one im talking about. Now turn your key to the on position and start the car. Your TPMS light should be off. If it is, tape the wire on this end so it doesnt fall out and you are good to go! Man that was easy. Ive been driving tacomas with this set up for a while, no fuses, no disabling the entire tpms system. It works. I just hope this post works since I dont really know how to do this yet. Good luck! Oh, btw Ive never tried this on anything newer than a 2009 so im really just assuming its all the same on 2010-2014's. K
This 5 volt source is the one generated by the engine ECU for all of the power-train sensors. I've considered using it for another purpose but did not because I wondered whether tapping into it could possibly cause driveability issues or phantom problems with a sensor that would be hard to diagnose. I simply do not know.
The OP is correct that certain years require that 5 volts be sent to the TPMS dash light LED to turn it off. Some have used 12 volts but I chickened out because during at certain times the voltage will spike to 14 volts or so. In the end I tapped into a 12 volt source and made a simple 5 volt stand-alone devise out of a few cheap semiconductors.
How does Taco'09 know all this stuff? Toyota tech? anyway I can only speak from the experience Ive had so far. On my 2009 taccoma I had routed the TPMS jumper wire to a +12v to turn off tpms light. I drove it for 8 months with no problems. I only tried this blue wire 5v thing recently on my new (to me) 2007 tacoma a few days ago but everything is good so far. I will report back in a month or so to let everybody know if anything goes wrong or not. To me, it seems fine. There is no voltage that comes from this blue TPMS wire, so all this is doing is feeding off the +5v wire. I guess you could say maybe it is changing the resistance on the blue wire providing the +5v? Anyway, I will happily be the guinea pig on this one..
KauaiYota, I cheat. I have all the technical manuals and have done a bunch of it myself. Even then I only get it right way less than 50% of the time lol.
The secret is when you have a success you brag it up......but when you smoke something you keep it quiet.
Please keep us posted on using that 5 volt source long term.
BTW, you will be really impressed when the real talent shows up and post.
to name a few?
You mean the likes of Pb, and toku58 to name a few?
Hello to all I have a taco 06 and Tried the ground to disable the TPMS on the dash, I tried several ground spots and the light still comes on, I even used an extended cable and tried the battery and still comes on. I was going to try to put 5v to the blue wire, but I'm not sure since that method is only for 2007 and up. Anybody here not successful that can give me a hint. I spent hours and still no able to get rid of the light on the dash. Any help will be appreciated.
#9 ·
Strange? I did mine and worked like a charm. Light has been out for several days now with no issues. Nice to have that annoying light gone!
#13 · (Edited)
FYI: 2014 spare has no TPMS, it's a different wheel, too; black steel & label says "For Temporary Use", even though it's the same tire as the other four. Probably "Temporary Use" because of no TPMS. Sounds like "lawyereze" to me.
Reactions: SCQTT
#16 ·
KauaiYota, thanks for the update....and where have you been? We have not heard from ya in a while.
Now try sending 12 volts back up to that sucker and see how long it lasts. Ha, just kidding.:grin:
Its always good when someone reports back that something they tried works and has not developed problems.
#20 ·
Interesting discussion. I bought a set of 2013 steel wheels removed from a 2013 Tacoma for my 2013 TRD Tacoma, which came with alloy wheels. Not that steel vs alloy makes a difference. The wheels came with sensors and lug nuts. The lug nuts for a steel wheel are different than on an alloy. On my 2013, the warning lamp flashes, than goes solid. It took a few miles for that to happen. After a few trips, the same thing. For the last few trips the warning lamp doesn't come on at all. Is it possible the system sees the new sensors since they come from the same year? I know all the sensors are given individual ID numbers. Got the codes from the replacement wheels. Don't see why the wheels have different ID's since there's only one warning lamp.
#21 ·
I bet you're storing your alloys with the original sensors nearby at home. Your truck is reading those and not the steel wheel sensors. You have to program the sensors in the ECM before it will see them. They use different codes in case you have two Toyotas. And you certainly don't want yours going off telling you low pressure when you drive by another Tacoma/Toyota on the highway.
#22 ·
TPMS disabled in a 2012
Thanks, KauaiYota! I can verify the "blue to blue" behind the glove
box DOES work on a 2012 SRS ! I have hated TPMS systems since they were conceived ! If you cannot be trusted to check your tire pressure, you probably should not be driving !
#24 ·
A 7805 three pin regulator will give you an amp at five volts if it's heat sinked, from a 12 volt source, but even free standing you'll get enough to fool the TPMS without overloading the device. Left terminal to 12 V, center grounded, and right one is 5 volts. Just tape it up well after soldering. They were under a buck at Radio SHack, now you may have t hit the internet. I'd be very leary of messing with a 5 volt logic line from the ECU, for fear of a spike getting back to the ECU and letting all the magic smoke out.
#27 ·
Thanks for posting this. I just did this mod for my '14 Tacoma. Using my voltmeter I found a blue wire that had +12V on it and connected it via a switch to the the blue wire that feeds the TPMS light circuit. I lowered the pressure on one tire to trigger the light and, then flipped my switch to "on", and the light goes off. My TPMS sensors are mounted on my aftermarket summer rims / tires, and I am installing Blizzaks on my factory steel rims for winter driving, but I did not want the hassle of dealing with another set of sensors. For the short 60 to 90 day time frame that we deal with winter in MD, I think I can manage to check the tire pressure manually. :)
#29 ·
Welcome aboard! :welcome: Please tell us where you obtained the switch and a part number if you would not mind.
FWIW I have not been advocating sending +12v back up to the LED. That LED was designed to turn off at 5v which is the trigger that comes out of the TPMS module.
Reason being that once you start the truck the voltage regulator can put out almost 15v for a short time depending on the charge in the battery and that is almost 3X the intended voltage. I've messed with LEDs enough that they can be easy to ruin. So on later trucks (not the earlier models) it would be wise IMHO to create a 5v circuit off that wire and then route that to the LED if you are so inclined.
#30 ·
Instead of mandating these expensive failure prone devices, we need simple legislation that if you sell gasoline then you must provide free compressed air and an accurate air gage. It also wouldn't hurt if people had to have basic maintenance training before getting a license to drive
I know so many people that have so much trouble with these tire pressure systems. It never ends.
